Author Topic: Jackson 715 tube tester help  (Read 196 times)
Offline daveone23Topic starter
« on: October 28, 2024, 11:30:07 am »
Need help with a 715 tube tester(identical to 115). The needle wont center. Meter is tested and good, caps are not shorted, has voltage 6c4 has 6.3 on filament.
What should I check and what caused the meter to center?
Re: Jackson 715 tube tester help
« Reply #1 on: October 28, 2024, 11:31:44 am »
