Author Topic: POST Hacking Rigol MSO5000 - POST HACKING TUTORIAL - DEEP DIVE  (Read 46840 times)
Offline BTOTopic starter
Re: POST Hacking Rigol MSO5000 - POST HACKING TUTORIAL - DEEP DIVE
« Reply #75 on: May 05, 2024, 07:55:58 pm »
I had the scope a few years ago and am no longer quite up to date:
Is it still the case that you have to renew the hack as soon as you load new firmware onto the scope?
If so, then nothing has changed in the last 5 years...
HI mate,
Not sure if you know yet, but now YOU CAN UPGRADE THE SCOPE AND HAVE ALL THE OPTIONS AND IT'S PERMANENT.
Go to the links in the first post to the Cloud and you'll find the files there and the PDF that explains it all, it's not hard
and many people have done it, You just need to know which model you have and that will determined which script you use to upgrade.
if you have 70MHz Model you use
rigol_kg2.py
if you have 100MHz Model you use
rigol_kg2_3_000.py
we've worked out a lot of the problems and it seems like it full steam ahead now
QUESTION EVERYTHING!!!
« Reply #76 on: May 05, 2024, 08:00:33 pm »
Hey Martin,
yes, you still have to use the patch after every update.
UDPATE :   NO NOT ANYMORE
We now have a PERMANENT SOLUTION, we are not using the Dr Mefist0 Patch method, but instead
the DrMefist0 FULLY LICENSED Method,   It totally works
Initially we had some problems with the 1 script where some people who had Models that WERE NOT
MSO5072
MSO5074
were having issues and the script wasn't completing.
WE'VE FIXED THAT. there are now 2 scripts  1 for the 70MHz and 1 for the 100MHz Models  Including MSO5000BND Bundle options.
after you do this, You won't have to patch again... EVER !!!
Just upgrade as new official firmware files become available, Nothing to worry about.
« Reply #77 on: May 05, 2024, 08:02:33 pm »
You need to keep up Martin72, things have changed.
That said, applying the original update following a firmware update is very straightforward; not at all a bind and keeps the MSO5000 fully featured.
Back on topic - Martin, thanks for the additional videos man, will work through them.
His question was not how easy it was.
With Rigol DS1000Z you applied the licenses and after that scope was unlocked and you didn't have to patch anything ever again, even if you loaded new firmware.
So his question was very on the topic, and he asked it because he wanted to keep up...
So answer to his question is : Yes, every time you load new firmware you need to patch up again, but process was made to be very easy, so it is not a problem. But you need to patch up every time,  it is not one time job as it was on a Z machine..
Hi Mate, Just touching base
Have you upgraded to the FULLY LICENSED METHOD YET ?
if you're still on the patch method.  Revist the URL in post 1 for the Cloud,  there is a PDF that explains everything.
« Reply #78 on: May 05, 2024, 08:06:09 pm »
Hello,
I was just wondering if there was a published 'hack'/upgrade for a Rigol MSO5072 with Firmware 01.03.02.02.  I was just about to follow the guide for 01.03.00.03 and then realized - I should stop!
Many thanks
Hi mate Just touching base with you,
WE HAVE A NEW PERMANENT LICENSING METHOD FOR THE MSO5000's
Have you done this yet, or are you still on the patch ?
if you're still on patch, go to the link in Post 1 download the PDF and follow the instructions,  it's easy, Lots of people have done it
and it's proven to be working
« Reply #79 on: June 22, 2024, 07:45:27 pm »
Hello,
Many thanks
Hi mate
Just in case you were still wondering, We've had a few advancements
1. THE UPGRADE for the MSO5000  Now works beautifully
2. Not only MSO5000 but MSO5100 and MSO5200
3. Many people have upgraded with success
4. There was only a small number of people that got an Assertion Error.
    BUT I RECENTLY FIXED THAT AS WELL.
NEW UPDATE : MSO8000 Is now also do-able and very possibly MSO7000.
        Also, 2 new scripts have been created for MSO5000 to cater for various scenario's
it's full steam ahead now.
Go to this link (on the unlock method by DrMefisto)
https://www.eevblog.com/forum/testgear/hacking-the-rigol-mso5000-dr-mefisto-licensing-method
Go to page 1
Go the MEGA Download link
DOWNLOAD THE PDF and read it and go from there
it will tell you what you need to download
and everything you need will be at the same link that is on that page.
Also,Since this thread is just about the videos.  Let's not do a discussion about unlocking here.
Instead go to the other link and discuss it over there.
I just wanted to put it here for the sake of awareness.
« Last Edit: June 30, 2024, 01:40:37 pm by BTO »
« Reply #80 on: June 30, 2024, 01:41:30 pm »
JUST CHECKING IN WITH EVERYONE
How are the video's going ? Does anyone have any questions, How's everyone going with their newly licensed Scopes ?
« Reply #81 on: July 12, 2024, 01:42:01 pm »
IF ANYONE IS STILL GETTING ASSERTION ERROR
ASSERTION ERROR IS SOLVED
WE HAVE A NEW SCRIPT
EDIT : This Post has been edited to include the latest script
- it's Faster
- Easier to use
- No need for you to know when to restart
1. The script has been Re-Written
2. There is a new Script
Same location
https://mega.nz/folder/A8cEgQRI#5FSoMrCurJi71T7VkRPgYQ
it's called
Rigol_MSO_LicensingUtility_2.10b.py
Grab it
NOTE : It's Based on the 2.10b script by asp, I've made a few changes so it's easier to read and understand what's happening at each stage.
           But all in all asp did the heavy lifting.
NOW READ THIS CAREFULLY
(SOME COMMANDS HAVE BEEN CHANGED)
1. it doesn't really matter what version your scope is on
2. Delete and discard of all other scripts that you have and use this one moving forward
   (it will work for ANY MSO5000, MSO7000 and MSO8000)
3. Ensure your working directory has the script copied into it
   and delete all Priv.pem files from it
4. Assume your I.P. Address is  10.1.1.666
RUN -h  HELP and CREDITS and to familiarize yourself with the commands you will be using.
Rigol_MSO_LicensingUtility_2.10b.py -h 10.1.1.666
5. Assume your I.P. Address is  10.1.1.666
RUN -i  INFORMATION
Rigol_MSO_LicensingUtility_2.10b.py -i 10.1.1.666
6. RUN -r REGENERATE PRIV.PEM
Rigol_MSO_LicensingUtility_2.10b.py -r 10.1.1.666
NOTE : RESTART WILL HAPPEN AUTOMATICALLY
NOTE : ACTIVATION AND LICENSING WILL HAPPEN AUTOMATICALLY
NOTE : YOU WILL BE ADVISED WHEN YOUR SCOPE IS RESTARTED AND READY AGAIN
NEW FEATURE ADDED ... REBOOT  (From Command Line) - No Need to press the button
Rigol_MSO_LicensingUtility_2.10b.py --reboot 10.1.1.666
ALSO, The Script runs much faster now,  Approx 1min for activation (not 15mins)
Now your scope will be activated and No Assertion Errors
After this
- Upgrade your scope to the latest version 1.3.3.0  if not already on it
- Do a Self Test
- Do a Self Cal
ENJOY
« Last Edit: July 21, 2024, 01:23:32 pm by BTO »
Offline nau
  • Country: th
« Reply #82 on: July 31, 2024, 04:40:02 pm »
Hi. This is my MSO 5072. (firmware 00.01.03.00.01) Can I use the instructions from the first page of this thread? Will the DS5000Update.GEL file work?
Please, can you help me? Write a manual with backup and update options...
« Last Edit: July 31, 2024, 05:07:26 pm by nau »
« Reply #83 on: August 01, 2024, 02:19:26 am »
OK, so it's a little old.... NO PROBLEM
YES YOU CAN
This specific thread was created (Not for Licensing and Hacking) but for scope understanding and it's features.
But i have however done you guys the courtesy of including and updating the hacking progress
Here is what you need to do
On the first page of this thread there is a link.
HERE IT IS
https://mega.nz/folder/OsJyFY5A#8uS0fmepgBdNrXqvnxmFfg
This is the link to the videos and everything else
TO UPGRADE, YOU ONLY NEED THESE 3 FILES
MSO5000 DrMefistoLicensing Method.pdf   THE INSTRUCTIONS
MSO_Rigol_LicensingUtility_2.10b.py        THE PYTHON SCRIPT
UPGRADING TO 350MHZ (1.3.3.0)             THE GEL FILE
Now, Just briefly  the 1.3.2.2 file is still there JUST IN CASE anyone needs it, But you don't really need it anymore
YOU WANT TO DO THIS
- You are on 1.3.0.1    YOU WANT TO IMMEDIATELY (Before any hacking)  Upgrade legitamtely to 1.3.3.0
so Use the GEL file, put it on USB, go into your scope, Select LOCAL UPGRADE and let it run and restart
- After that, it'd be a good idea if you did a SELF CAL
- Then Crack out the instructions and read them,   Do your backups as instructed
- And finally you're gonna install python as instructed and then you're gonna License your scope and see FOREVER,
it'll be easy , don't worry
if you have any problem, don't hesitate to reach out and if it's still hard, and we need to do a 1 on 1 session, that's no problem.
The script has come a long way since it started,  it's now really easy to do and you don't need to really worry about restarts or hanging
or starting on a certain version or if you are on a version that is too low or whatever.
the only thing is, that VNC Viewer isn't supported until version 1.3.2.2   so you should upgrade to 1.3.3.0 to get all the supported versions.
You see, when the script looks at your scope (at the time is tries to license it) it gives you ALL AVAILABLE options,
Now if your version is lower there are some stuff that won't be available because of that.  so STEP 1 - Upgrade to the latest version
Do that, Tell me how you go with it
Now, i didn't really want to make this post about Activating, but i'll make an exception this one time so that others can briefly read it.
but all future stuff like this, I'm going to redirect to here
https://www.eevblog.com/forum/testgear/solutions-and-troubleshooting-hacking-the-rigol-mso5000-series-oscilloscopes/
Which is also why i haven't given you detailed information here and i just put it in bullet point form.
but feel free to PM me if you like or email me
Offline nau
  • Country: th
« Reply #84 on: August 01, 2024, 03:30:30 pm »
I did everything according to the instructions in the files. Folder - UPGRADING TO 350MHz (1.3.3.0)
The step-by-step instructions are very detailed.
The update was successful! Thank you very much!
I'll drink to your health!!!
« Reply #85 on: August 02, 2024, 01:06:36 am »
WELL DONE, Congratulations, Glad to hear it
Now
Do Self CAL
Do Self Test
then watch the videos and have fun with that
Enjoy your scope
Offline nau
  • Country: th
« Reply #86 on: August 03, 2024, 01:41:26 pm »
Yes, of course.
I will follow your advice.
The following users thanked this post: BTO
Offline BRZ.tech
  • Country: br
« Reply #87 on: October 29, 2024, 12:20:35 pm »
Hi to @BTO and other guys.
@BTO, do you have any news from RIGOL regarding the FW changes you sent?
Did they send you any Beta version of the new FW?
Tell us about your experience with the new FW?
thanks. 73.
Offline Odd-Job
« Reply #88 on: November 07, 2024, 09:53:17 am »
BUMP'
For all of the EEV forum who now have HotRodded MSO, do your self a favour and go this YOUTUBE site and watch this video.
Do each video as an exercise and you will get so much more satisfaction out of your new tool and learn so much in a short time..
The author Tom has not posted for aver 2 years and I fear he may not be well, or even still physically here, so make his legacy live on and his work not lost to a lack of storage.
Great work BTO.
As a side note, tomtektest on youtube did a 33 part overview of the MSO5000 and functions.
Definately have a look and give him a like on the videos.
Here's the playlist:
His channel: https://www.youtube.com/@tomtektest8042
(Don't know the guy, just saw the videos 3 years ago when they were released).
Again, thanks BTO.
Just a ghost, trying to control a skeleton riding a rock hurtling thru an  infinity of octal~fractal space
The following users thanked this post: lmamakos
