Siglent SDP3303X-E says you dont have short circuits on your 5v ( digital section ) anytime.
Bad design, same with the Rigol.
Edit : me happy GW fanboy.
Just reading this topic : https://www.eevblog.com/forum/testgear/rigol-dp832-random-reboots/
Yes aware and we don't use the 5v section for any critical work, always for critical use the two variable voltage and current limit sections. We have 3 SDP3303X-E and they are good down to low voltage and currents as mentioned on those 2 outputs. One unfortunately isn't usable because of the current limit offset mentioned caused by my improper calibration, which makes for a risk for critical use and not acceptable to us.
GW seems like a good alternative, we'll definitely be looking at those for any future power supply needs.
BTW not a bad design by Siglent, they chose a simple linear regulator to keep within a cost budget....likely why the GW costs more
Best,
