You still on the old gear? You really need to upgrade to the KKeysight 344461A, I am waiting for the even newer 3444461A, it is coming out any day now
This reminds me of the TI calculator from the 70's, I had a TI 30, the key bounces all the time creating double/triple digit entries, terrible defect in a calculator. Their higher end models were much better, but none came close to a HP with RPN.
Back on topic, the recommended cal period is 1 year, with a max of 2 year per recommendation from Keysight. So I would say a cal for your best meter may be a good investment, you can use it as a transfer standard for your other meters across all voltage ranges and measurements. It minimize the curse of multiple versions of truth when you own multiple DMMs. Back in the old days, I had one analog meter, I never questioned its reading. The arrival of my second meter was perhaps the beginning of my OCD.
As the meter ages, the drift reduces, as evident in my two almost 10 years old 34401As, those are rock solid meters and a joy to use. But for a new meter, a cal after a few years of use, though may not be necessary, could be a nice treat for yourself.
