Author Topic: Just Upgrade my Rigol DS1054Z to the 4.04 firmware  (Read 29118 times)
Offline ebclrTopic starter
« on: July 21, 2016, 07:38:36 am »
It's even better
Now XY is big, At least Rigol update firmware frequently, My poor Owon still on the same firmware as I bougth 4 years ago
Offline alsetalokin4017
Re: Just Upgrade my Rigol DS1054Z to the 4.04 firmware
« Reply #1 on: July 21, 2016, 08:30:34 am »
... for certain values of "Frequently" ....
Last update was at least 10 months ago. And the update just released still has the "Pluses" spelling error.     :-//
Offline Fungus
« Reply #2 on: July 21, 2016, 09:12:18 am »
What about other things?
[Updated Contents]
v00.04.04.00.07  2016/07/19
     - Added the full-screen display in the XY mode
     - Modified the Trace data of average sample mode
     - Fixed the bug of system halted for wave persistance in the Zoom mode
     - Fixed bugs about Measure
Does "Fixed bugs about Measure" mean the measurements now work in math mode?
« Reply #3 on: July 21, 2016, 09:53:37 am »
I don't know. I haven't installed the firmware yet. Maybe someone who has done so can run through some tests to find out.
After reading about the one user who had the bad experience (LEDs misbehaving) I'm reluctant to try it. Even though I would love to have the fullscreen x-y display.
Talk about "not parsing"... I've never been able to decode much of the Chinglish in the changelogs. What does "Modified the Trace data of average sample mode" actually mean? Did this address some bug, and if so which one?
« Last Edit: July 21, 2016, 09:56:22 am by alsetalokin4017 »
Offline Fungus
« Reply #4 on: July 21, 2016, 10:33:21 am »
That doesn't sound like a firmware problem to me - he says the scope runs fine apart from the LEDs. Seems more like a hardware problem (bad flash memory cell?).
"average sample mode" is easy.
"Modified the Trace" sounds like they modified the wiggly line on screen.
Offline jjoonathan
« Reply #5 on: July 21, 2016, 11:29:20 am »
On my DS4014 I've seen much more granular quantization than I ought to when taking certain measurements (e.g. it will fluctuate between 1.000V and 1.034V, nothing in-between, on a quantity that should involve heavy averaging). This suggests to me that they're doing something silly like storing the math result in an 8 bit field *after* dividing by N. IIRC I saw the same problem on my DS1054Z -- maybe this patch fixes it?
« Reply #6 on: July 21, 2016, 12:44:52 pm »
So you think that by "average sample mode" they might mean Average _Acquire_ mode? Or perhaps they are referring to the Measurements "average" which is something different?
"Modified the trace _data_" could mean just about anything, from modifying the wiggly line on the screen, to modifying what goes into the Measurements averages, to something else entirely.  What bug could this be fixing?
Offline rstofer
« Reply #7 on: July 21, 2016, 02:22:32 pm »
It never said anything about FIXING a bug, they simply inserted a brand new bug called "Modified the trace_data...".
Offline mgotter
« Reply #8 on: July 22, 2016, 12:58:51 am »
How did you get the update?  I still see the previous version on Rigol's website.
Offline kwass
« Reply #9 on: July 22, 2016, 03:45:15 am »
It's here: http://int.rigol.com/Product/Index/4
-katie
The following users thanked this post: mcinque
Offline mgotter
« Reply #10 on: July 22, 2016, 04:33:08 am »
Thanks!
Offline The Doktor
« Reply #11 on: July 22, 2016, 07:24:02 pm »
Do all the upgrades still work after this update
Offline madires
  • A qualified hobbyist ;)
« Reply #12 on: July 22, 2016, 07:35:52 pm »
Do all the upgrades still work after this update?
Yes, I've updated mine today without any problems.
« Reply #13 on: July 23, 2016, 02:38:09 am »
All upgrades / Hacks stay there as is before
Don't forget to do a recalibration after the update
Offline OE2WHP
  • Country: at
« Reply #14 on: August 03, 2016, 12:19:54 pm »
Updated my DS1054z. All options still working. Can't confirm the LED bug. Seems to work fine so far.
73
Offline rbak
« Reply #15 on: September 09, 2016, 12:56:30 pm »
I am curious about the "Added the full-screen display in the XY mode" that was added in the 00.04.04.00.07 release. Can someone perhaps post a screenshot of that here?
« Reply #16 on: September 09, 2016, 11:53:29 pm »
Here you go.
« Last Edit: September 10, 2016, 12:02:51 am by alsetalokin4017 »
Offline rbak
« Reply #17 on: September 09, 2016, 11:57:24 pm »
Excellent! Thank you very much!
« Last Edit: September 09, 2016, 11:58:59 pm by rbak »
Offline raptor1956
« Reply #18 on: September 10, 2016, 09:03:37 am »
Is there a wiki or some other source that list the various firmware versions and when they were released?  I have a fairly new 1054Z with 00.04.03.SP2 and board version 0.1.4 and I'd like to have the full size XY screen but since there appears to be some bugs I think I'll hold off for a while.  Just curious about hoe frequently they do an update...
Brian
Offline Fungus
« Reply #19 on: September 10, 2016, 10:57:35 am »
There's less bugs in this version than ever before.
Offline iainwhite
  • Measure twice...
« Reply #20 on: September 10, 2016, 02:14:57 pm »
Brian
Brian,
Here are the latest release notes (see attachment) - there is a history.
Online RoGeorge
« Reply #21 on: October 10, 2016, 11:54:40 am »
  • Is there a wiki or some other source that list the various firmware versions and when they were released?
    Download the firmware, unpack it, then read the txt files. It contains all the history with dates, starting from the first released firmware up to the current one.
  • In the file 'MSO_DS1000Z Release Notes.txt' is written:
    v00.04.03.01.05   2015/06/16
         - Added the mutual communication with DG4000 Series
    Does anyone know what "mutual communication" is about, please?
« Last Edit: October 10, 2016, 11:57:59 am by RoGeorge »
Offline pastra
« Reply #22 on: November 09, 2016, 10:31:11 am »
I can't find the firmware on rigol site (http://int.rigol.com/Product/Index/4), only 00.04.03.
Am I blind or has it moved?
Anyone have a direct link to the download?
Offline Bicurico
  • Country: pt
    • VMA's Satellite Blog
« Reply #23 on: November 09, 2016, 10:44:50 am »
It has been removed, because a user has detected a potential bug. This was discussed on a separate thread on this forum... I am too lazy to look up the thread, but you should easily find it.
Regards,
Vitor
Offline StuUK
« Reply #24 on: November 09, 2016, 11:27:16 am »
Regards,
Vitor
The link has been removed but the file can be downloaded from it's original location here:-
http://int.rigol.com/File/ProductSoftWare/20160914/DS1000Z(ARM)update.rar
That's not to suggest you should given that they must have a reason for removing the latest update link
