A nice demonstration of the effect of limited bandwidth, but a little unfair on the poor little DSO138.
I built one at Christmas as a little stocking-filler present and yes it is a bit of a toy, but at least at a toy price (unlike all those pocket MP3 player based pocket DSOs!). I was wondering about doing a mini review but wasn't sure if I dare put it in the Test Equipment section.
It's actually not that bad, yes its limited bandwidth makes it only suitable for looking at audio, 555s and power supply ripple, but the screen and UI are pretty good (quite cute) given the button limitations. The TL084 based analog section is manually switched (the s/w reads the switch positions to reflect the correct v/div and voltage readings on screen) which means that the cursor can be left on timebase most of the time.
It's useful in the same way as having a cheap DMM kicking around is useful (or a $20 LCR ESR Transistor checker?). You can float it on a supply (battery pack or isolated mains adapter) to monitor something while you're doing other stuff. The on screen readouts are quite useful.
P.S. JYE Tech have released a new 060 s/w version that corrects the time / frequency measurements to work on average input rather than zero crossing, so no missing measurements on DC coupled now. It now also has single button auto trigger level setting. Unfortunately they have also added an annoying anti piracy/cloning message (aimed at Chinese clones, primarily Saintsmart) that pops up at startup. Is nothing sacred.
Edit: It even seemed worth the effort of putting into a box...
