I don't know if you're still looking for the Wavetek 90 manual. I haven't been able to find one either, but what I have found is that there are a lot of similarities between the Wavetek 90 and Wavetek 288. The manual for the Wavetek 288 is available online.
A common problem that I have found in the 288 and the 90 is that relays tend to go bad, which causes calibration errors. The relays don't fail completely, but the contact resistance will be >3 ohms, instead of being close to zero.
