Just got a defect Keithley 182 (with connector
Some docs taped to it say it was last tested 2006 and the display isn't working due to a power supply (5VAC,60VDC) failure. Added was the remark, that this supply block isn't awailable by Keithley anymore (only the hole board) . Seems to be used in many Keithley 2k products however ...
Build a new one (
https://dev.xdevs.com/issues/858) or try to find a used one?
Since it's said for these instruments to generally recap it, I now ask myself: Give it try to check the display power block or recap first?
Would be a nice thing to measure a 732 against the 5700 ...
