Hello everybody. I just bought a Keithley and boy is it grand. The d.c. volt, and ohm readings are spot on, original calibration was all that was done to it from factory. I was quickly disheartened though, as when I pressed the button for a.c. voltages or amps it showed no op. Which after diving through the manual means that the 1950 option is not present. My question to any one out there is what did that option consist of; is it some rom chips, a breakout board and would it be in the realm of possibility to find one and flash some roms if any body has them?
