Author Topic: Lecroy WR64MXi teardown...  (Read 16618 times)
Offline Wuerstchenhund
  • Able to drop by occasionally only
Re: Lecroy WR64MXi teardown...
« Reply #25 on: November 26, 2014, 12:16:32 pm »
Topside of processing board, with the inputs/acquisition board removed....love the hirose board to board connections
Those connectors are actually the weak spot on the WaveRunner (M)Xi Series. as they tend to loose contact due to thermal stress. As a result, one or more channels (usually its Ch 2 and 3) won't show a signal (or only a very distorted one), and when using the vertical offset for those channels the trace moves as long as the know is turned but as soon as the adjustment stops the trace jumps back to somewhere near the center.
LeCroy does repair the connectors, although at a price. If they fail, maybe they can be replaced with a more durable solution.
Offline TunerSandwichTopic starter
  • I kiss on the first date
« Reply #26 on: November 26, 2014, 01:15:02 pm »
Not sure why those would lose contact.....quite tight and bolted and braced.....I have used similar Hirose b2b connectors in quite a few places, including high thermal, high stress applications, and never once had a problem.  If they are losing contact/continuity it has to be on the board side, not the b2b joint.
In fact I am using them on a daughter card (high current) POL...in a battery powered portable design.  The devices sitting on the card are pushing over 15 amps and run consistently at around 74deg C....their passive cooling solution dissipates straight into the PCB.....not one failure in testing or use.  The connectors don't carry the high current up to the card, but they carry critical and sensitive serial (bit corn) and other command/protocol data....those signals are free of any degradation, even beyond nominal operation temps.
Is the issue documented at all?  If so what was the resolution?  rework of the pad to edge?
« Last Edit: November 26, 2014, 04:20:18 pm by TunerSandwich »
In Soviet Russia, scope probes YOU.....
« Reply #27 on: November 26, 2014, 02:23:25 pm »
Exactly, which is the cause of the problem.
In fact I am using them on a daughter card (high current) POL...in a battery powered portable design.  The devices sitting on the card are pushing over 15 amps and run consistently at around 74deg C....their passive cooling solution dissipates straight into the PBC.....not one failure in testing or use.
I don't know your design of course but it may well be that the PCB has plenty of room to expand. In the WR(M)Xi, the fixing posts prevent the aquisition board from having space to expand when heating up, which causes thermal stress which results in stress on the connectors themselves.
My scope is one of the affected ones, and according to LeCroy support this is a well known problem with the (M)Xi. Not sure if its documented outside but that is probably true for most things of these newer scopes.
The solution they offer is a board repair, apparently involving replacing the connectors. It's not cheap, but of course still a lot less expensive than just swapping the boards.
« Last Edit: November 26, 2014, 02:26:49 pm by Wuerstchenhund »
« Reply #28 on: November 26, 2014, 03:29:14 pm »
That is very interesting....
When we use Hirose b2b connectors we always use a small elastomer or fiber washer, on the standoffs, that bolt the daughter cards to the main boards.  Hirose themselves recommend this "finger tight" fit.
I wonder if simply putting a thin fiber washer at the base of those bracing blocks, and not going more than "finger tight" would help this issue.  It would allow for about 0.15mm expansion...
LeCroy is doing virtually the same thing on the Hirose connector on the back of the main board, where the probus interface card mounts.  They have a longer screw, a thin belville washer, and a nylon spacer on the back of the screw.
Another option would be a small sliver of silpad to "float" the acquisition board a bit off the main board.
Will try both of these methods and see if it causes any issues.
« Last Edit: November 26, 2014, 03:35:03 pm by TunerSandwich »
« Reply #29 on: November 26, 2014, 11:23:40 pm »
Since you have a later production date it might well be that your scope already has provisions for alleviating the problem.
My unit from 2005 unfortunately has been hit (Ch 2 and 3 are affected). I also don't have the tools to re-solder or replace the connectors. Luckily I still have two other scopes.
BTW: if anyone knows a shop in the UK or in Europe who can replace the connector and does a thorough job then please let me know, as the LeCroy repair is quite expensive.
Offline Lukas
    • carrotIndustries.net
« Reply #30 on: November 26, 2014, 11:38:19 pm »
This is used when the scope stops acquisition and goes into calibration cycle to compensate for temperature variations and changes in the signal path.
On these scopes there's a setting to disable internal calibration for thermal compensation but will still re-calibrate when larger changes in the vertical setting are made.
I've always been wondering why LeCroy scopes need to do this, as the rest of the industry gets away without interrupting the user every now an then...
« Reply #31 on: November 27, 2014, 12:10:32 am »
Do you possibly have a picture of the failed pads?  VERY curious to see exactly how it fails.  I am going to stick the fiber washers in mine, as a precaution.
From what I can tell on my unit, most of the chips and the lecroy code says around Sept. 2009....but the HDD lot code is 2005.....
BTW my fans are Young Lin, rated 4.2W.  The blade profile is one of an air mover.....def not a static pressure fan.  Does any of that ring a bell, or are these the most current fan rev?  Still considering swapping them for some Delta air movers I have (wish I knew how much total current the fan regulators are rated for).
« Reply #32 on: November 29, 2014, 07:14:43 pm »
Unfortunately not. I had it open (for the upgrades) but then put it back together. I didn't look closer to what's wrong with the connectors, but my gut feeling is that maybe they just need resoldering. But as I lack the tools I just put it together and now occasionally use it with two channels only. If I can't find a cheaper alternative then I'll have to send it to LeCroy for repair.
I wouldn't worry about the hard disk, maybe it has been replaced at some points in the past or they bought a large charge in 2005 (which wouldn't be surprising, considering that by then SATA was the newest thing).
Sounds like your scope already has the uprated fans.
I'd just leave it as it is.
« Reply #33 on: November 30, 2014, 02:56:27 am »
I was able to successfully "float" the acquisition board, from the main processing board.  I tried nylon and fiber washers, but then realized the through holes (bolt down points) were part of the ground/isolation plane (beeped them out).  So I wound up using split lock washers (very small aluminum) on the backside of the main board, where the screws feed through.  I tested the expansion and it offers a decent amount of "play" in the connector.  enough to allow for movement under a thermal condition.
Everything fit fine in the chassis, and the backspacing on the screws doesn't interrupt any critical mechanical spacing.
Scope is back together and running flawlessly.  I also modified the spacing on the LC bus daughter card, using a nylon washer on top (replacing the steel unit).
I did some testing on the draw of the delta fans, and they weren't acceptable (over 10 watts/fan).
With the new CPU the cpu fan is running on overdrive 90% of the time.  I used some Antec series 7 thermal compound on the CPU block, but it just isn't a large enough mass or fan to cope with the increased heat.  I am going to have a new CPU block cut and utilize some more of the horizontal space in the mobo enclosure.  I noticed a chassis opening just beside the block, so I might have it cut and install a semi-external passive cooling solution.  The amount of heat being kicked out of the scope is WAY beyond where it was with the Celeron.  I am a bit concerned, especially since the CPU block is adjacent to a section of the PSU, which contains a lot of electrolytic caps.  Overall lecroy didn't do very well (IMO) as far as cooling solutions for this chassis.
This might all be un-necessary/overkill, but if anything the added noise from the CPU fan running at full tilt all the time is enough to justify the attempt (for me).
When I strip it down again, for HDD and wiring changes, I will try these mods.  I found a slick, straight through, IDE/SATA bridge....I was going to modify it's connectors and mount, to clamp directly to the replacement SATA drives chassis.  I want to minimize the ribbon cable slack and keep it from bunching in the chassis (obsessive I know).
i will update this thread with more pictures of the mods, when I tear it down again.  I might also modify the MOBO chassis upper panel (that holds the LC bus connector) to space a tad bit higher.  It doesn't align as well as it should, and I am concerned about potential strain on the connector.  A couple slim nylon washers should give it a extra mm and bring the connector up just a bit on the side panel cutout.
« Reply #34 on: December 02, 2014, 12:22:33 pm »
The heat sink and fan should be sufficient for your processor. However, unlike the old Celeron, the Pentium-M does support SpeedStep which clocks the CPU down if the load is low. XP supports SpeedStep, but depending on the power settings it might just nail the CPU down on constant full throttle.
I think (can't check as I'm at work at the moment) that SpeedStep also needs to be enabled in the BIOS. The same might be true for temperature control of the fan.
Well, its narrowly built, but don't forget that this design has proven to be running fine in the field for now more than 9 years with no heat issues (aside from the acq board connector problem on earlier batches) or higher than normal PSU failures.
The other thing is that if you modify too much (i.e. more than just RAM, CPU and hard disk) LeCroy may refuse repair if you ever need it.
However, I agree that the build quality is only average on the (M)Xi Series, and no match for the Iwatsu-made scopes (WR, WR2, WP900) or the first and second generations of X-Stream scopes (WM8k, WP7k, WR6k).
As before, I wouldn't recommend to go further with modifications to such a scope, especially when every mod can easily introduce new problems. You may end up with an unreliable piece of kit (I understand you bought it for your business, so I guess you want something reliable).
« Last Edit: December 02, 2014, 12:24:14 pm by Wuerstchenhund »
« Reply #35 on: December 02, 2014, 10:06:54 pm »
I will dig around the BIOS and OS tonight.  I was trying to avoid going in and modifying core system parameters (until I get that drive backed up).
I am also NOT noticing a real improvement in scope application processing (maybe it's me but it honestly seems worse than before).  However the boot times are VERY much improved.
I will post some screenshots....when I run SpecAn the CPU throttles up to max load and pegs there, while the UI completely locks out.....something seems a bit wrong about that
« Reply #36 on: December 03, 2014, 09:05:16 am »
There's not much to modify in Windows. Just go to Control Panel - Power settings and change the power profile from the high power profile ("always on" or something similar, can't remember at the moment) to a flexible profile (i.e. "Laptop").
That's strange, as the difference should be quite noticable. It does suggest that there's something wrong with your setup.
Since you say it's worse than before, and your system seems to be running excessively hot, it may well be that the CPU runs into throtteling due to overheating, which would explain why it's so slow.
I can switch on mine and check the temperature readings tonight.
Indeed, this shouldn't happen. The old Celeron-M 310 1.3GHz has a TDP of 24.5W and lacks SpeedStep, so it's running full throttle constantly. The P-M 745 1.8GHz I have in my scope has only 21W, and supports SpeedStep so won't run full throttle unless the load is high (and even then puts out less heat). Even the fastest P-M processors only put out 27W which is only 2.5W more than the Celeron M, and again they run with SpeedStep. You shouldn't really see any increase in heat after the CPU swap.
« Last Edit: December 03, 2014, 09:44:15 am by Wuerstchenhund »
« Reply #37 on: December 03, 2014, 10:03:09 am »
I was playing around in BIOS earlier today and found a problem.....the temp throttling was set at 60 deg C and the CPU was idling at 61 deg C.....playing around with some settings now....also need to play with some FSB speed settings to match up this RAM and going to manually set timings.....I think the SPD on this stick of ram is wonky.....the timings are off of the manufacturer stated ratings....
I normally would just set all of this stuff manually and move along, but I am a bit paranoid...seeing as I have a real lack of experience with LeCroy scopes.....I am a bit paranoid to just treat it like "another computer"....probably being over cautious.....baby steps  :-BROKE
Offline abraxa
  • Sigrok associate
« Reply #38 on: October 31, 2017, 08:08:44 am »
Unfortunately, the pictures are no longer available. Would it be possible for you to upload them elsewhere and replace the links if it's not too much work?
