Hello there!
I'd like to ask the Keithley DMM specialists if you have a hint for me on my Keithley 2000 DMM.
The device is from 1997.
Caps have been replaced this year. Everything under them was dry and clean, no problems here.
An ESR-meter even showed acceptable values for C and ESR, after 23 years, not bad :-)
It has been calibrated by a service company like a year ago.
My only concern is, that _sometimes_ on built-in self-test, the error 400.2 appears.
Meaning: Testing 5 times in a row = 3 results with no errors, 2 results with 400.2 come up.
Results are independent from run-time. Happens cold, happens warmed-up (on for hours).
Precision: Almost all measures are bang-on, I compared them e.g. to my DMM6500.
The only thing that _may_ be, is, the AC volt and ACI, which are a little bit out of spec (as far as I can say), which in particular doesn't matter (to me) that much.
=> So, live with it, or chase down some rabbit-hole? :-)
Many thanks in advance for ideas and opinions!
Regards,
Sebastian
