The BK supply you linked to is 600V but 500mA rated at 210W max. I thought you were looking for a 500W supply?
In any case, BK and brands like Sorensen are not really ocmparable. One can argue that BK is moving into more industrial applications where reliability is paramount but brands like Elgar, Sorensen, HP, Kikusui and Delta Elektronika have been for years. Experience does count and these brands are generally conservatively engineered and well built to last decades. If your voltage rating is lower, I'd recommend looking at Rohde & Schwarz offerings from the previous generations as well. Lower priced options here are Lambda and Acopian.
As to programming these supplies, that's where these brands ask for the big bucks. Programming in this context means not only voltage and current control but also customizable waveforms and sequences. Being able to control the supply for V and I remotely is much easier and some people do refer to that "programming". Remote control on the industrial brands mentioned above is usually fashioned with either an analog DC voltage or a 0-10K pot external to the supply. Very simple and PC programs or fancy wiring are usually needed.
If your needs are less than 100mA but into kV, there is another class of supplies you can investigate - these are 1kV+ supplies that are designed for X-Rays, blood processing machines and they sell under names like Spellman or Glassman High Voltage, both of which are owned by XP Power now. These are rugged units that work day in and day out with no complaints.
Have fun and good luck!
