Author Topic: Uploading Siglent SDS 2304X Logic Channels  (Read 1956 times)
Offline daveb1Topic starter
« on: December 24, 2018, 09:07:27 pm »
I've just purchased a Siglent SDS 2304X and found to my horror that I can't remotely upload the digital channels via USB or VXI. It now looks like I can't save the entire data set to an external USB flash disk either.
I've captured 14Mpts of 8 digital channels but when I save as binary to a 4GB external disk the resulting file size is in the 10's of kB. I suspect it's saving a screen dump. When I try to save as .CSV or .DAT I get the message "Store data failed".
Has anyone managed to get an entire logic data set out of one of these scopes ?
Thanks
Dave
Offline colorado.rob
Re: Uploading Siglent SDS 2304X Logic Channels
« Reply #1 on: December 24, 2018, 09:20:12 pm »
I have tried.  I have talked to Siglent about this directly.  It cannot be done.  The only Siglent MSOs that allow access the digital channel data are the newer X-E models.  You can confrim this by reviewing the Siglent oscilloscope programming guide.
It is a serious shortcoming of the scope.  But it is one that Siglent, at least when I last spoke to them, claim can not and will not be addressed.
« Reply #2 on: December 24, 2018, 09:57:34 pm »
Hi colorado.rob
Thanks for your reply.
Just to be clear, as well as not being able to remotely upload digital data have you neither managed to save a full data set to a USB disk ?
If there's no way to get digital data out then that's an unforgivable glaring omission and mine is going straight back !
Dave
« Reply #3 on: December 25, 2018, 11:06:07 pm »
I have not tried.  That would be useless to me.  However, if it had the ability to save to USB, there would be nothing to prevent Siglent from sending it out the LAN interface.
The cheap Saleae knock-offs do a better job as a logic analyzer than most MSOs.
