Products => Test Equipment => Topic started by: balage on September 16, 2020, 10:27:14 am
Hi Fellowes,
Can anybody help me identify which connector fits the rear interlock connector of the good old Keithley SMUs?
This is the 3-pin version, not the 4 that is used with the picoammeters. I just want to try buying one instead of changing them to LEMOs instantly.
can you give me some diameters measurements, pins spacing etc ..... not sure but i think i have a tons of them at my job ... i have the chassis mount too, not pcb mount
so far
external od 8mm
space between pins 3mm ?
Switchcraft tiny QG series, model TA3FX
pdf attached
On the images it seems this is the one I need. And available at Mouser and Digikey.
I will measure the dimensions to be sure, but it must be the one!
Thanks! Recognizing a specific connector on an image - that needs experience. :D
It is known as "mini XLR connector"
