Author Topic: to program by font keys the HP 3458A for a rolling average (mean)  (Read 3434 times)
Offline peluleTopic starter
  • What is business? It’s other people’s money
« on: September 20, 2015, 09:42:24 pm »
Hope, there are some users of the 3458A out there, more experienced than me.
I like to make rolling average (mean) measurements with my 3458A.
Preferred to have a running average out of the last 8 or last 16 measures.
The 3458A shall operate stand alone (no connection to a computer).
Searched in the manual and the WWW (also in this blog), but could not find a solution.
With my Datron 1281 this is a quite easy job:
just select "AvR" in the "Math" menue and use the "Config" to set the "N" value to define the number of measurements to average.
Any ideas?
You will learn something new every single day
Offline DimitriP
Re: to program by front keys the HP 3458A for a rolling average (mean)
« Reply #1 on: September 20, 2015, 11:28:36 pm »
The only place I found about enabling Math operations is on page 118, and very deceivingly it seems , Math operations are enabled by sending a command via GPIB.
Hopefully someone else will chime in to confirm or deny ....
Anyone...  Bueler....
from the manual ( http://literature.cdn.keysight.com/litweb/pdf/03458-90014.pdf )
page 118
Enabling Math
Operations
To enable a math operation, send the MATH command (for real-time) or the
MMATH command (for post-process) followed by the operation parameter
(DB, DBM, FILTER, NULL, PERC, PFAIL, RMS, SCALE, STAT, or one
of the temperature-related parameters; refer to "Measuring Temperature,
later in this section for a listing of the temperature-related parameters). After
enabling a math operation, it remains enabled until you disable it, cycle
power, execute RESET, or execute one of the PRESET commands. For
example, to enable the NULL operation, send:
OUTPUT 722; "MATH NULL" !ENABLES REAL-TIME NULL OPERATION
or
OUTPUT 722; "MMATH NULL" !ENABLES POST-PROCESS NULL OPERATION
Re: to program by font keys the HP 3458A for a rolling average (mean)
« Reply #2 on: September 21, 2015, 08:52:32 pm »
This fits to my findings so far.
A tip from a friend:
Use the user programming feature and define it to one of the user definable keys (as I did for the TEMP? command).
But we did not find the solutiion for the rolling average, just the one time average (STATS, MEAN).
My solution so far:
set the NPLC to 10*N, according to the manual, in case NPLC is > 10, the tools does N x (NPLC=10 measures) and builds the average.
-quote-
if you specify 60=PLCs (1 second of integration time at a 60 Hz = line frequency) using the NPLC command, the mulitmeter averages six 10 PLC readings.
-unquote-
But this is still no rolling average unfortunately.
Offline dacman
« Reply #3 on: September 22, 2015, 11:12:05 pm »
The closest thing on the 3458A to a rolling average would be MATH FILTER.  It is definitely not a rolling average.  With NDIG 8 set, and others at default (NPLC 10 and DEGREES 20), I think it takes about 100 seconds to settle (with 60 Hz line power).  If DEGREES were set to 10, it would take about 50 seconds.  It's stated to act like a 1-pole RC low-pass filter.
