Author Topic: InCircuit ESR Meter  (Read 3443 times)
Offline janengelbrechtTopic starter
    • JP-Electronics
InCircuit ESR Meter
« on: November 07, 2014, 12:13:07 am »
Im looking for an incircuit ESR meter that actually works: Which works at voltages low enough so they wont trigger any semiconductors on the PCB where one is meassuring ESR in a cap.
I have narrowed my search down to this: http://www.ebay.com/itm/Digital-ESR-Meter-Test-In-Circuit-Electrolyte-Capacitor-Resistance-0-01-30-Ohm-/261350478205
Anyone know this meter ?
Offline mathsquid
  • I like math.
Re: InCircuit ESR Meter
« Reply #1 on: November 07, 2014, 12:51:51 am »
I have a meter that looks mostly the same, but has red and black banana jacks on the side.  I don't have anything to compare it to, but it seems okay.  The attachments have pics that show the meter's test signal.  (How do you include pictures inside a post?)
    • JP-Electronics
« Reply #2 on: November 07, 2014, 01:08:27 am »
Yir it looks much the same. Thx for the pics. I can see the voltage is okay for incircuit analysis :)
Offline zaoka
« Reply #3 on: November 07, 2014, 04:33:51 am »
That new version may be using 4 wire measurement method?
    • JP-Electronics
« Reply #4 on: November 07, 2014, 12:55:24 pm »
Seems legit..... something like this (only with a microcontroller instead):
Offline DanielS
« Reply #5 on: November 07, 2014, 06:58:06 pm »
Unless you can isolate the component you want to test, you have to take your in-circuit measurements with a fistful of salt since your measurements will include effects from other components in parallel including alternate series paths between your measurement points. Not suitable for much more than sanity-checking - you are basically measuring the Thevenin/Norton equivalent of your circut as seen from your test points assuming active components are open-circuit.
