Author Topic: Kelvin clips  (Read 1000 times)
Offline GiallograleTopic starter
Kelvin clips
« on: November 07, 2024, 06:50:32 am »
I need some Kelvin clips for a used Agilent 34401A multimeter, through hole and tweezers for SMD.
I'd like decent quality, and as I'm in Asia, I'll be looking on Taobao. Are there any good-value brands to look out for?
Thanks!
Online squadchannel
  • Country: jp
  • deepl translate user
Re: Kelvin clips
« Reply #1 on: November 07, 2024, 06:54:48 am »
ETA ETA3108
not bad for the price. :-+
https://en.tw-eta.com/index.php?c=category&id=22
The following users thanked this post: Giallograle
Re: Kelvin clips
« Reply #2 on: November 07, 2024, 11:32:17 am »
Good value, but unshielded?
Have I missed something?
Offline HighVoltage
Re: Kelvin clips
« Reply #3 on: November 07, 2024, 12:00:41 pm »
What are shielded kelvin clips?
Offline coromonadalix
Re: Kelvin clips
« Reply #4 on: November 07, 2024, 12:42:11 pm »
the 5th wire,  some  are coax shielded and all 4 probes shield are connected together (5th) to a ground body of the instrument
as for efficiency ???
Online squadchannel
  • Country: jp
Re: Kelvin clips
« Reply #5 on: November 07, 2024, 12:49:56 pm »
I don't know what you mean by shield kenvin clips, but usually coax cable shields are used with a guarded(BNC GND ring) on the meter side and unconnected on the kelvin clip side.
the 34401, it is a regular 4mm banana, so you can cut a high-quality banana cable(pomona etc...) and connect it to the kelvin clip.
Online tszaboo
Re: Kelvin clips
« Reply #6 on: November 07, 2024, 01:10:13 pm »
Where do you connect it on your multimeter?
Re: Kelvin clips
« Reply #7 on: November 07, 2024, 01:37:44 pm »
Solartron 7075 has a 5-pin Fischer or Lemo connector with the guard being one. Some other older meters, like Fluke 8300A iirc just have an extra banana/binding post
Online tszaboo
Re: Kelvin clips
« Reply #8 on: November 07, 2024, 02:21:36 pm »
Sure, and the old 3458A at work had that.
How about the Agilent 34401A like the OP has?
Offline Kean
    • Kean Electronics
Re: Kelvin clips
« Reply #9 on: November 07, 2024, 02:44:36 pm »
The 34401A and 34465A manuals mention this in the section Low-Level Measurement Errors
For this reason, you should apply low-level ac voltages to the multimeter through shielded cables. You should connect the shield to the input LO terminal.
For reference, the Keysight Kelvin probe set P/N 11059A uses RG174 cable with the shields terminated to the 5 banana plug (open at the Kelvin clips), and an extra alligator clip at the other end.
They are quite expensive, but I bought mine a long time ago when they were significantly cheaper (but obviously not as cheap as decent Chinese ones).
https://www.keysight.com/au/en/product/11059A/kelvin-probe-set.html
« Last Edit: November 07, 2024, 02:54:36 pm by Kean »
Re: Kelvin clips
« Reply #10 on: November 12, 2024, 06:51:18 am »
Thanks everyone.
After ordering the ETA4551 (Kelvin clips to 4mm plugs, unshielded), I eventually found the ETA3206 adapter plug - 4mm plug to 4mm socket suitable for sheathed connectors - on www.tw-eta.com. ETA has a shop on Taobao where I got them for $1.5 each which will allow the use of the usual test leads across devices.
Lots of other useful leads in a wide range of formats, and test fittings on this site, eg BNC set to SMD so I'm ordering a few more leads.
Offline timeandfrequency
Re: Kelvin clips
« Reply #11 on: November 12, 2024, 08:02:52 pm »
Hello Giallograle,
Check out this small clip with a strong spring.
« Last Edit: November 12, 2024, 08:04:39 pm by timeandfrequency »
