Author Topic: Kepco JQE 25-4M modification  (Read 1292 times)
Offline biotron345
« on: December 01, 2015, 06:45:30 pm »
Recently got one of these really cheap. I'm considering adding a digital meter. I had one lying around and tested it - appears to work. Is this a sensible mod? Also I'm a bit puzzled about the patchbay of screws on the back. Can anyone shed any light on this?  :popcorn:
Offline Teste
  • Country: br
Re: Kepco JQE 25-4M modification
« Reply #1 on: December 01, 2015, 10:00:00 pm »
If you want to measure voltage and the voltimeter impedance is high enough, there is no problem to install a digital voltimeter on our PSU.
Kepco also sells these JQE power supplies with digital voltmeter + ammeter readouts.
You can download the Kepco Service manual on these links: (however there aren't for your power supply model - JQE25-4M - a "similar" should be JQE55-2)
http://exodus.poly.edu/~kurt/manuals/manuals/Other/KEPCO%20JQE55-2%28M%29%20Instruction.pdf
http://exodus.poly.edu/~kurt/manuals/manuals/Other/KEPCO%20JQE36-15%28M%29%20Instruction.pdf
http://physics.ucsd.edu/neurophysics/Manuals/Kepco/JQE%206-22M.pdf
http://mmrc.caltech.edu/MPMS/Manuals/Kepco%20JQE6-45M.pdf
