Author Topic: HP3563A upgrade with Newscope 5 display unit.  (Read 4315 times)
Offline Alex NikitinTopic starter
  • Femtoampnut and Tapehead.
    • A.N.T. Audio
« on: January 07, 2017, 10:23:14 pm »
The HP3563A Control Systems Analyser in my lab was not getting much use, for two reasons - one is the fan, which is so loud that it is impossible to sit next to the unit without incurring a bad headache after an hour or so, and the second is a somewhat aged CRT display with blurry lines, which has also developed a strange kind of a whistling sound for first 30-40 minutes of operation. I was planning to upgrade the display with the Newscope 5 LCD screen available for some time now and the display has arrived over a month ago. At last today I've found some time to do it, as well as to check the type of fan I need to get (and to promptly order it from RS as the exact model is still available after 25 years).
I guess I will be using the analyser a lot after I'll replace the fan in few days time. Here are some photos - I have to say the upgrade went very smoothly and the instructions for the display unit are very good.
Cheers
Alex
That is how the display looked a while ago:
Now to the rest:
« Last Edit: January 07, 2017, 11:17:55 pm by Alex Nikitin »
Offline radhaz
Re: HP3563A upgrade with Newscope 5 display unit.
« Reply #1 on: January 07, 2017, 11:35:05 pm »
That's pretty impressive.  :-+
Offline cdev
« Reply #2 on: January 07, 2017, 11:55:53 pm »
So, its now color- that's really nice.
How does it determine what colors to use where?
    • A.N.T. Audio
« Reply #3 on: January 08, 2017, 12:07:31 am »
According to the manufacturer, the colours chosen are close to what later similar HP/Agilent equipment used. There are four colour schemes (user selectable by rotating the focus pot at the back of the analyser), including the original mono green.
Cheers
Alex
« Last Edit: January 08, 2017, 12:11:02 am by Alex Nikitin »
The following users thanked this post: cncjerry
    • A.N.T. Audio
« Reply #4 on: January 08, 2017, 12:18:25 am »
Here is the fan   :) .
Cheers
Alex
Offline Keicar
    • My YouTube Channel
« Reply #5 on: January 08, 2017, 12:32:10 am »
Very impressive result - I'd consider the Newscope LCD kit for my 3562A (same issue, gets a bit smeary once you turn the intensity up far enough to see anything) were it not for having a spare (NOS) CRT stowed away in a box under the bench (I'd feel guilty for not using it).
Cheers,
Karl.
Offline shteii01
« Reply #6 on: January 08, 2017, 12:40:49 am »
Drop some oil into the hub.  Might solve your noise issue.
Cheers
Alex
    • A.N.T. Audio
« Reply #7 on: January 08, 2017, 12:52:38 am »
Maybe - and not for very long anyway. The replacement fan will be here on Tuesday, so I would rather do it properly  8) .
Cheers
Alex
