I would strongly recommend DMM4050. This thing turns on/off within 0.5 second, and warms up quickly to get specified accuracy.
Besides, it comes with clean and simple VFD display, not the LCD rubbish, plus free GPIB.
Its specified accuracy in virtually all ranges are better than 344x1A, and are comparable to 34470A.
List price: $1450, but I believe if you wrote a letter to TEquipment, they can give you more than [eevblog coupon] off.
Last time I got 20% off on an item, so expect $1200-ish price.
Rigol is not a very good competitor in this case, as the price is only $200 cheaper than 34461A.
Consider K2000 instead, you can get a used one on eBay for $500, and the specs are better than K2100, comparable to or better in some terms than 34461A.
Thanks for the input.
I do like the LCD, but im not sure how the issue around boot time is an issue once the instrument has booted ? I will mostly use simply use the USB interface/scpi with Matlab, the legacy GPIB isnt really a requirement for me.
Also note, the Keysight 34461A has a big display, the UX is clean and the layout works well, also Benchvue works very well. so thats a big winner. im almost 90% certain this is what I will be investing in.
thats $1,086.03, its Rand 24K, I can almost buy a small used car for that price here where I live.
I do agree, the TEK has better specs in some respects.
http://www.testequipmentdepot.com/tektronix/digital-multimeter/digital-multimeter-dmm4050.htm6.5, 0.0024% Accuracy, Bench Digital Multimeter
Product Features:
Measures Volts, Amps, Ohms, Frequency, Period, Continuity, Diode Test, Capacitance, & Temperature
6.5 Digit Resolution (24 PPM)
Basic VDC Accuracy of up to 0.0024% (1 yr.)
200 mV to 1000 V Voltage Range, with up to 10 ?V Resolution
200 ?A to 10 A Current Range, with up to 1 nA Resolution
200 ? to 100 M? Ohm Range, with up to 1 m? Resolution
CAT I 1000 V, CAT II 600 V
3-year Warranty
Available Functions & Features
Volts, Ohms, and Amps Measurements
Diode and Continuity Testing
Frequency Measurements
2×4 Ohms 4-wire Measurement Technique
Dedicated DC Leakage Current Measurements
Six Dedicated Buttons for Fast Access to Instrument Setups
Limit Compare Mode for Pass/Fail Testing
Connectivity
Front 2×4 Measurement Inputs
USB Host Port on Front Panel for Easy Storage of Measurement Data and Instrument Settings
RS-232 on Rear Panel for Quick PC Connectivity
Includes USB to RS-232 Interface Adapter Cable
Includes National Instrument’s LabVIEW SignalExpress™ TE Limited
Edition for Connecting Your Bench
