For bench use I'd skip the Fluke 8846A and get the DMM6500 instead. Having some graphing / logging facilities on a bench DMM can be very handy at some times.
This seems to be an oft-repeated discussion. IMO any discussion of these three somewhat different meters should include their differences. They're all 6.5 digit bench meters, but that's all they really have in common. I don't recommend the 8846A to people in general because it isn't the best choice for many uses, but for the
OP person wanting a 'second opinion' meter, it probably would, in fact, be the best by far. The DMM6500 is simply a different class of instrument and has a lot of features--digitizing, the scanner card option, etc--that probably make it quite attractive for actual engineering use. If I was going to buy another meter, I probably would go with it just for the scanner card function.
The 8846A is a quick and efficient service bench meter, it goes from dormant (standby) to almost any range in 2 seconds and 3 button pushes or less. Maybe 5 button pushes if you want dual display or something special like Hi-Z. It also has 1000VAC, 1G-ohm and 10V diode ranges and is rated CAT I/1000V and CAT II/600V, unlike any competitors. It also has actual and specified accuracy (if you read carefully) that significantly exceeds the other contestants. So if those are the things that are important to you, the 8846A should not be overlooked. I personally don't mind the display and logging can be done with Flukeview Forms (which is admittedly not great), LabView or
HKJ's excellent Test Controller. YMMV.
As for the current discussion, as an individual or very small business, I'd be very reluctant to invest in a 34465A given the recent issues with the model and the company. It seems that unless you cycle them out before the warranty ends or you have an ongoing
paid service contract with them and are a big enough fish to merit their attention, you may be left with scrap metal for your investment. You might be better off with a decent HP 34401A and a PC for logging. But again, YMMV--I have a high tolerance for things that are a bit odd or cumbersome to learn and use but a very low tolerance for things that are unreliable, don't last or can't be fixed.
