I've wanted to take some samples with a DMM.
A 34410A. I used to do this 10 years ago. DMM us connected through USB.
You loaded an excel plugin, clicked a button. It took a sample, and placed it in the excel sheet.
It was great, you didn't have to do anything, setup was 1 minute.
Go forward 10 years to today. I have a 34465A on my desk, and new version of excel.
I tried doing the same. So I downloaded IO libraries suite. Then I downloaded the new command expert, because the old excel plugin is no supported anymore. Then the software downloaded some, because it didn't have the DMM plugin. We are at 1GB downloads already. I clicked on the plugin in excel... and it pops up a window where you have to manually input all the commands. Gone are the days, where you can just take a sample.
Ah well, how hard it can be.
CONnect. MEAsure. -> ERROR
WTF
Well, when you send the MEAsure command it wants the value immediately, and gives an error. Their own smart command editor doesn't know how to use their own instrument. But whatever
CONnect. TRI* wait FETCh ->ERROR
ok, some more issues. Trigger source is bad. I tried setting up with the front panel, its not possible
CONnect TRIGger:SOUrce BUS *TRG FETCh -> OK
So I have a working script it only took me an hour to do this.
I click in excel, it tells me. " Sequence completed successfully"
Ok, where is my data? Nobody knows. For the last 2 hours I cannot figure out actually how to export the data to excel. The entire measurement shouldn't take more than 30 minutes including taking all the samples.
I wrote python scripts faster, by sending commands to the open port via ethernet faster than this.
I'm extremely disappointed. If you don't support the old tools, thats fine. But taking away functionality isn't. It shouldn't be more complicated than pressing a button and getting a reading. Daniel, if you are reading this, there is absolutely no excuse for this.
