Hello all
I have MXA Analyzer. It is works good, but I need higher phase noise performance for some measurements. At present time, my analyzer have E4410-60108 reference assembly. This assembly used for devices with serials < MY/SG/US52330000 and have phase noise around -106 dBm/Hz@10 kHz. In documentation, I found, that devices with serials > MY/SG/US52330000 have different assembly N9020-60200 and higher phase noise performance –114 dBc/Hz@10 kHz. So my question is it possible to replace E4410-60108 to N9020-60200? Is it fit inside MXA with serials < MY/SG/US52330000 ?
I noticed devices with serials > MY/SG/US52330000 also have different Chassis Base, Rear Panel numbers and I worry, maybe it is impossible to retrofit N9020-60200 inside...
