Have been getting to know the MXR respectably well since the weekend, though I have had a few niggles especially with noise floor consistency.
The MXR is big heavy beast and sits firmly on the bench and totally intimidates the vast majority of the rest of my bench equipment. If it could talk 'If you are hard enough mate' would be its strap line.
Not having used a keysight GUI for a while it has not taken to long to reacquaint myself with its workings.
Drop down menu's are nice and simple, set wizards are good touch, the vertical and time measurement bar on the left hand side is nice touch and simply slides away when not required.
Probe quality is very good and locks with a reassuring clunk.
Boot time around the 2.20 mark, around 30 seconds slower than the R&S RTO and Lecroy Wavepro series BUT significantly faster than the Tek 6 range at 5.45 minutes (rumoured to be a new model in the offing but currently delayed).
Solidly constructed and sporting eight channels the MXR makes judicious use of my main diagnostic and research area (some relocation of shelving required if this body builder of a scope is going to reside in personal lab).
Right off the bat the first thing that grabs you is noise this machine makes, it is seriously loud. Think early 90's desktop PC during the summer. While I appreciate there is a lot of hardware in this Challenger tank chassis its does make a big noise (Rigol mso5000 owners can smile in the knowledge an MXR would out drag them comprehensively in a sound off).
All this hardware does generate quite a bit of heat, the lower portion of the screen after a couple of hours in a well ventilated room reaches 52C. The side of the scope where all the connectivity is situated (and the IEC) does climb to around 64C even with the copious amount of air that scope moves to cool its Microsoft server like processing ability.
The logic probe is sited on the right hand side (due to the lack of front panel space taken up by the eight channels) So the probe cable has to travel through 90 degrees. Trade off from the large processing ability. RTSA thus far hummmmmmmm........... basic at best.
This is brief write up at the moment due the unit having 'issues' and is being returned to Keysight UK for investigation, obviously the Sighound ability to throw things out of whack has struck again.
Some screen images of the power supply meas I did yesterday plus some FFT and basic eye images. Last image is of the noise floor at Keysight own settings to achieve the 9 bits of ENOB er its some way off, hence the unit being returned for investigation.
Keysight have been thoroughly professional in their handling of this hiccup and I will be receiving a full loaded and correctly functioning unit next week. It is how a problem is dealt with which tells you great deal about the company ethics and working practices so big thumbs up for Keysight UK on this matter
The images are labelled as to the relevant measurements.
The last image is of the noise floor measured @ 20Mhz hardware BW plus 16bits of SW filter engaged @ 1mv per div and 200ps HTB claimed is 45uv as you can see it it somewhat off that figure, see explanation above.
