Author Topic: Cheapish tweezer SMD testers: Uni-T UT116A and Mastech MS-8911  (Read 4861 times)
Offline SilverSolderTopic starter
« on: February 19, 2021, 03:46:00 am »
Today, I attempted to use these two tweezers to determine the values of the resistors and capacitors on the small PCB in the picture.
The performance difference between the two in this use case is pretty amazing...  the Mastech returned plausible looking readings on all of the passive components, while the Uni-T failed to get a reading at all on some capacitors, and got very implausible looking numbers on others.
Both work well when the components are out of circuit, but there is no comparison when it comes to testing in circuit...  the Mastech is in a different league.
Offline Algoma
Re: Cheapish tweezer SMD testers: Uni-T UT116A and Mastech MS-8911
« Reply #1 on: February 19, 2021, 03:56:25 am »
Looking at the spec sheets, that Mastech offers both more resolution and accuracy for the same 6000 counts.
Smallest Capacitance supported:
Mastech 0.1pf  ±(2.0%+10)
vs
UT116A has only 1pf resolution and much lower accuracy  ±(3.0%+50)
UT116C isn't any better..
But the Mastech doesn't measure voltage and test LEDs and Diodes, like the UT116A/C can.
« Last Edit: February 19, 2021, 04:18:07 am by Algoma »
« Reply #2 on: February 19, 2021, 03:59:17 am »
Smallest cap is 100nF from what I am able to glean.
Offline Algoma
« Reply #3 on: February 19, 2021, 04:07:38 am »
Those tiny caps, at that frequency.. those could only be a few picofarads at best. 100nf = 100000pF  A vastly larger SMD. Perhaps the meter is picking up something else.
Offline Algoma
« Reply #4 on: February 19, 2021, 04:10:22 am »
apologies, 100nf does come that size.  I can only imagine the density of the layers inside.
« Reply #5 on: February 19, 2021, 04:32:34 am »
I was pretty surprised by how much capacitance they pack into such a tiny space...    Welcome to 2021, I guess?  :D
100nF is well within the range of both meters, so there must be something else (resistance in parallel?) that confuses the Uni-T.
« Reply #6 on: February 19, 2021, 06:48:37 am »
10 yr old SMD caps from my small stash..... 10uF 0805 still in the tape and 330uF in the even older ST3 SMD tweezers.
« Last Edit: February 19, 2021, 07:10:34 am by tautech »
Online indman
  • Country: by
« Reply #7 on: February 19, 2021, 07:19:18 am »
Quite right, since these tweezers have completely different circuitry!
MS8911 is a bridge LCR meter principle with low voltage selection at test contacts.
UT116A (C) - Based on a standard DMM processor for testing components outside the circuit.
« Reply #8 on: February 19, 2021, 02:10:36 pm »
The caps on this board measure as 0603, so not the smallest possible format....
The largest capacitor I was able to quickly find, in the 0603 size, was 10uF!!!   :o
That's pretty amazing...
« Reply #9 on: February 19, 2021, 02:43:48 pm »
On this board, it works fine in 1V mode.  So, that part of the test was fair!  It seems the Mastech measurement algorithm is better.
Offline Kosmic
« Reply #10 on: February 19, 2021, 03:19:34 pm »
It's not just an algorithm. The technique they use to measure components is completely different. Like indman said, the UT116A  is more like a DMM and the MS8911 a LCR meter.
Check the output of both device. You will find a nice sinewave on the MS8911 and probably some kind of slow ramp on the UT116A.
Iet labs as a nice document on LCR measurement http://www.ietlabs.com/pdf/application_notes/030122%20IET%20LCR%20PRIMER%201st%20Edition.pdf
« Reply #11 on: February 19, 2021, 05:52:36 pm »
I can confirm that my "regular" handheld meters can't get a reading on the small caps on the board either.
I guess the conclusion is -  use an LCR type tweezer if you want to probe PCBs with it...
Would be interesting to see how the Mastech compares with other LCR tweezers.  So far, I'm pretty impressed, but I'm starting from a low level of expectation!  :D
Offline bc888
« Reply #12 on: February 19, 2021, 09:44:39 pm »
Thanks for the review. Anyone compare the Mas8911 to the "DT71 Mini Digital Tweezers SMD Tester" that Dave recently did a video review on?
« Reply #13 on: February 19, 2021, 09:50:41 pm »
My money is on the Mastech being better although one of their earlier ones was not much chop vs my ST3 so I gave the thing to a mate that didn't have any SMD tweezers.
Offline Bud
« Reply #14 on: February 19, 2021, 10:32:57 pm »
Small physical size capacitors lose more capacitance at nominal voltage then their  bigger physical size brothers. This is in addition to capacitance loss due to the type of dielectric.
« Reply #15 on: February 19, 2021, 11:14:35 pm »
So it is only 10uF when not installed in a circuit?  :D
Offline Kosmic
« Reply #16 on: February 20, 2021, 03:25:50 pm »
The DT71 is another of those "DMM in a tweezer form factor". I would expect the MS8911 to do a lot better.
Offline tszaboo
« Reply #17 on: February 20, 2021, 10:39:51 pm »
Power Supply :  1x3V CR2450 Battery
Is it really that hard to get a product right?
Offline Bud
« Reply #18 on: February 20, 2021, 11:07:44 pm »
This may be a shock to you, the answer is pretty much yes
« Reply #19 on: February 20, 2021, 11:46:33 pm »
I am not a big fan of that decision either.   That said, (1) battery life has not been an issue so far, (2) what are the alternatives at this price point?
