Author Topic: Keysight U173xC series LCR meter shows ESR and capacity at once?  (Read 12162 times)
Offline tigr
  • Country: ua
Re: Keysight U173xC series LCR meter shows ESR and capacity at once?
« Reply #25 on: June 09, 2017, 08:09:22 pm »
I have one of these Peak Electronics ESR meters and it works really well and fast for ESR measurements.
Especially "in circuit" measurements.
Yes.Very good device.I would buy a new version with a higher resolution.
« Last Edit: June 09, 2017, 08:11:27 pm by tigr »
Offline zaoka
« Reply #26 on: June 09, 2017, 11:29:53 pm »
Would you prefer PEAK to U173xC series for trouble-shooting?
Neither of these. Get CapacitorWizard for ESR and use multimeter for capacitance. Analog ESR meter is way faster for troubleshooting purposes.
Offline carl_labTopic starter
« Reply #27 on: June 14, 2017, 06:02:53 am »
http://midwestdevices.com/
That one? 200$... :-\
Can't you built it yourself for a few bucks? AC generator+ AC current indicator?
This one doesn't look bad:
https://www.eevblog.com/forum/projects/5-transistor-esr-meter-design/
« Last Edit: June 14, 2017, 11:05:32 am by carl_lab »
Offline kripton2035
« Reply #28 on: June 14, 2017, 06:22:43 am »
here you go : http://kripton2035.free.fr/esr-repository.html
warning: problem actually with hosting, does not work from some countries (but going better ...)
« Reply #29 on: June 14, 2017, 06:29:01 am »
Exactly - cannot open your link...
Offline kripton2035
« Reply #30 on: June 14, 2017, 12:26:27 pm »
I'm now waiting for another hosting to store a copy there ... but it's seems long to make !
The following users thanked this post: carl_lab
Offline zaoka
« Reply #31 on: July 03, 2017, 02:30:27 am »
ESR meter should be able to measure up to 50ohm and that scale from 0 to 2ohm uses 1/3 of the scale..
If you make money fixing stuff that CapacitorWizard will get paid off from 1 or 2 repairs and will last you for years..
Offline kripton2035
« Reply #32 on: July 03, 2017, 05:51:22 am »
just FYI my ESR site clone is online now. see signature.
use the one that can be seen in your country.
