Author Topic: What it this device?  (Read 3462 times)
Offline nikonoidTopic starter
« on: July 03, 2017, 01:17:53 am »
I bought this "millivolt source" very inexpensively on eBay mainly to salvage low EMF tellurium copper binding posts. This seemed 5 times cheaper than buying new.
In fact it turned out to be a precision voltage divider that is still spot on and usable down to microvolts.
On the inside it is full of precision wire wound resistors.
I can also see connectors marked Br1, Br2, Sw1 and Sw2 and it might be a bridge of some sort. Even after partially reverse engineering circuit diagram I still cannot figure out how to use them.
The device seemed to be made by James Biddle, but I cannot find anything similar from James Biddle online.
Would anyone know what it is? Are there any documents available? Thanks.
Sent from my iPhone using Tapatalk
Offline Nusa
Re: What it this device?
« Reply #1 on: July 03, 2017, 02:40:48 am »
Intriguing. What is that glass-tube looking component on the back of the precision dial? Can we get a close-up?
« Reply #2 on: July 03, 2017, 02:49:26 am »
It is a wire wound resistor (10 Ohm). Same value as most of resistors in the box.
Offline Nusa
« Reply #3 on: July 03, 2017, 02:55:47 am »
Ah, the glass look was an illusion. Thanks.
« Reply #4 on: July 03, 2017, 03:17:25 am »
Resistors appear covered with epoxy, probably for humidity protection. So I guess that explains the glass look.
Offline WastelandTek
« Reply #5 on: July 03, 2017, 03:25:35 am »
please don't scrap that for the binding posts
I'm new here, but I tend to be pretty gregarious, so if I'm out of my lane please call me out.
Offline Vgkid
« Reply #6 on: July 03, 2017, 03:37:30 am »
They are used in systems that use strain gauges in a bridge setup.
« Reply #7 on: July 03, 2017, 03:52:39 am »
I like old equipment and this piece it in meticulous shape. If I can figure out a good use for it, I definitely will not scrap it.
« Reply #8 on: July 03, 2017, 03:54:21 am »
Would that be to emulate strain gage?
Offline Vgkid
« Reply #9 on: July 03, 2017, 05:33:51 am »
Correct. It us used to divide the excitation voltage down to a level used to simulate the output of the strain gauge. That way, it can be read by whatever is being used to interpret the output.
Offline Vgkid
« Reply #10 on: July 03, 2017, 06:19:35 am »
It would either be epoxy, or a wax coating.
Offline ebastler
« Reply #11 on: July 03, 2017, 06:44:21 am »
These guys (apparently an importer/distributor) have a large selection of old Biddle and Megger manuals online, altough they might not go quite as far back. Any indication of a model number on your device?
http://www.biddlemegger.com/cgi-bin/webshop.cgi?config=megger&uid=jeuwukkl149906390058&command=link--MeggerManuals.html
EDIT: Ah, just made out the catalog number on the Biddle tag in your first photograph -- 603020, right? In which case they unfortunately don't seem to have the manual online. I wonder whether this device was originally made by Megger, as Biddle was apparently their US distributor. That might explain the bolted-on Biddle name tag. There are some other documents on that web site for similar model numbers, which refer to Megger instruments.
« Last Edit: July 03, 2017, 06:52:53 am by ebastler »
