Products => Test Equipment => Topic started by: jimb on April 19, 2017, 03:58:12 am
Title: KK Moon Dual Channel sig gen
Post by: jimb on April 19, 2017, 03:58:12 am
Hopefully I'm not stepping on any toes.
I just received a KK Moon function generator. Dual channel 25MHz DDS.
Installed the Software but... wait there was none. At least no app. Just drivers.
I tried the app written by one of the group in the thread  "My software to control Chinese DDS Function Generator" and....
It worked sort of.
When connecting, it paused and then reported ""There was a problem connecting".
It does work sort of. Bottom line reports "Not connected to DDS" but the signal tab functions work.
Sweep controls work sort of. Seems to sweep one channel but not tother.
Arb Waveform seems to loads the file but the DDS reports memory empty.
On powerup, it displays as:
MHS-5225A R5.04
MingHe (c)2015
Any one else have this model?
I tried configuring a terminal program to 57600/8N1/HW but got no response.
Thanks for any help you can provide with this.
Certainly has some stability and roll off issues.
Seems to give up at about 22Mhz.
But... what should I expect for 76$ CDN.
Regards,
Jim Brooks
Title: Re: KK Moon Dual Channel sig gen
Post by: NYG on April 26, 2017, 04:18:32 pm
Looks the same as the  newer 12bit MHS-5200A. If you haven't done it yet just do some searches on MHS-5200A.
