Author Topic: TinySA Ultra stuck in Listen mode on startup  (Read 275 times)
Offline szoftveresTopic starter
« on: January 22, 2025, 07:03:09 am »
I once turned off my TinySA ultra in Listen mode - now it starts up in this mode by default every time; I have to manually set it to normal display mode at each startup.
Is there a way to reset this behaviour to factory default (i.e. start up in normal display mode), without deleting the factory calibration data?
« Last Edit: January 22, 2025, 07:07:23 am by szoftveres »
