Author Topic: Koolertron 30MHz DDS Signal Generator PC Software  (Read 1050 times)
Offline r042walTopic starter
« on: March 29, 2023, 04:00:26 pm »
I have a Koolertron 30MHz DDS Signal Generator and I would like to install the PC software.  There are two links on the Koolertron website pointing to the Amazon S3 server and neither of them work.  I think I need the file DDS.rar
Does anyone have a private copy of this that they could publish for me?  I have reached out to Koolertron support but have not received a reply as of yet.
Thanks in advance!
Offline DRL
Re: Koolertron 30MHz DDS Signal Generator PC Software
« Reply #2 on: April 01, 2023, 03:32:27 am »
I believe that Koolertron is just a distributor, and your generator is a rebadged Feeltech. The Feelelec website is actually pretty OK, and you should be able to find a better manual and the software you want there under “Downloads”.
http://en.feeltech.net/
Good luck!
