Hey folks…
Long time listener first time caller. I’m an old newbie - I know a little about a lot of things!
I have been given this unit (a rebadged juntek psg9080) from a friend as I’m taking an online course building the Elenco AM/FM kit. He has only used it for generating waveforms for audio equipment - never used it for modulated waveforms.
The instructions for the kit say to set up the generator for a 1 kHz tone, 455 kHz am modulated carrier, at 80% modulation (depth) and connect it to a test point on the kit through a 0.001uF cap. Then increase the generator’s amplitude (Vpp) until you hear the tone from the radio’s speaker.
On the generator, the modulation setup is on one page and the amplitude adjustment and tone frequency is on another page. My experience is that you have to set the amplitude and then switch back to the modulation menu to get the generator to “trigger”. I switch back to the function screen to adjust the Vpp and the generator stops sending the modulated carrier until I switch back to the modulation page.
Is that right? Is there another way to do this? I have used an older Heath RF generator and you could vary the amplitude in real time - you activated the modulated carrier, set the tone frequency and dialed the amplitude up or down. It’s a PITA at this point. The manual sux.
Any guidance is greatly appreciated.
