Author Topic: Korad KA3005P power supply: UI changes  (Read 14286 times)
Online 5U4GB
Re: Korad KA3005P power supply: UI changes
« Reply #50 on: February 11, 2024, 09:09:59 am »
The KKG305P is a complete new and different device (even a KD3005 is not comparable to the KA3005) and it's definitely worth a new thread here.
It also seems to be practically nonexistent, Botland.de has it and that's about it, and of their range the 305P model is marked as EOL.  Also from one of the very few discussions of it it essentially looks like a fixed KA/D3005 rather than a new product, e.g. the annoying adjustment-lock is removable as with newer-FW 3005s, the memory-overwrite is fixed as with newer-FW 3005s... it looks like the KKG305s are just 3005s with window dressing, so this is probably the best place to discuss them, because they seem to be just 3005s with UI fixes.
« Last Edit: February 11, 2024, 09:15:15 am by 5U4GB »
The following users thanked this post: DaneLaw
Online 5U4GB
« Reply #51 on: February 13, 2024, 09:46:47 am »
Significant improvement: A short press of the "Lock" button enters a mode where you can adjust voltage or current via the encoder and arrow buttons without any timeout. There were many complaints about the short timeout in earlier versions. To lock and unlock the keypad, a long press on Lock is needed.
Just found where I'd seen this earlier right at the start of the thread, this change doesn't seem to have made it into the currently-shipping KA3005D yet, it still has the annoying short timeout where you keep having to press the Volt/Amp button every single time you make a change  Wanted to test the power consumption and light output of a 24V LED strip at lower voltages and every 1V step required re-enabling changes again, grrr.
Offline Pfriemler
« Reply #52 on: February 13, 2024, 10:03:08 pm »
Just found where I'd seen this earlier right at the start of the thread, this change doesn't seem to have made it into the currently-shipping KA3005D yet...
It would not suprise me if there are still "old" versions in stock to sold as new after two years. On the other hand, we still have no other versions than the Welectron KA3005P+ series proved with the newer firmware. I couldn't believe that KORAD did some changes only for Welectron while still deliverung "old versions" to the rest of the world.
once you do it right, it works :-)
Online 5U4GB
« Reply #53 on: February 14, 2024, 09:58:34 am »
The one I got was dated December 2022, 1 1/2 years after the post describing the change, so it's probably not just a supply-chain issue.
Does anyone who has a KKG-series one want to post photos of the insides?  For that matter, does anyone actually have a KKG?  From this Korad catalogue posted to the mikrocontroller.net forums they have a pretty confusing variety of models allegedly out there now.
Offline littleboot
« Reply #54 on: February 28, 2024, 12:54:50 pm »
instead of a custom temperature fan controller, I bought a PWM fan controller on Aliexpress:
Search for "12V PWM fan controller"
https://vi.aliexpress.com/item/32973504131.html
Prices fluctuate a lot, the one I ordered was €2.79 delivered
Operating instruction of this thing are very badly described, I found this video explaining how to change the temperate and fan settings:
and a thin 80mm fan:
https://vi.aliexpress.com/item/1005005952005094.html
NO-8010-PWM-BLACK
€4.75 delivered
Thin was not required but I wanted a branded fan (assuminh it would be better, more silent).
Everything works perfectly, the lab supply is silent now! :scared:
I forgot to add A additional capacitor on the 12V fan supply but, I have not checked the ripple.... just thought of it while typing this post :palm: (maybe I open it up again but seems to work perfectly so I think I will leave it like this)
- Put the thermristor of the PWM fan controller into the hole next to the NTC on the board.
- Stored the original fan inside the supply, If I ever need it
« Last Edit: February 28, 2024, 01:04:20 pm by littleboot »
Online 5U4GB
« Reply #55 on: February 29, 2024, 11:32:50 am »
Hmm, for only a tiny bit more you can get something mainstream like the Arctic temperature-controlled fans, they use a FDB for quiet operation and come with a built-in temperature sensor on a short cable.  For an 80mm fan you want the Arctic F8 TC.  I used to have one of those somewhere but ditched a whole bunch of fans ("the fan club") during a clearout a year or two back, sigh.
Online 5U4GB
« Reply #56 on: February 29, 2024, 11:48:31 am »
That would be interesting to see and was actually my first thought, have you partially negated one of the main benefits of a linear supply by adding switching noise to parts of the circuit?
Offline littleboot
« Reply #57 on: February 29, 2024, 12:53:14 pm »
Thank you for your reply I decided to open up the lab supply again.
I wish I knew about the Arctic F8 TC sooner I would have probably used it, however I'm quite happy with the AliExpress fan controller because I can configure it.
I'm glad I opened up the supply again and did a measurement, the supply noise is horrendous (did not expect it to be this bad :wtf:). When I'm finished with the measurements I will post measurement data before and after as well
Offline littleboot
« Reply #58 on: February 29, 2024, 09:49:53 pm »
Finished the measurements, as mentioned before the supply voltage is horrible, not only that it is actually load dependent ~20Vrms (light load, new fan standby speed) not 12Vrms.
I don't like the over voltage for the fan, but if it dies it dies, problem for future me
The fan controller AliExpress page is says it will operate from 8V to 18V. I looked up the LDO part number (78l05) on LCSC and it seems it can handle 35V max, assuming the 0603 capacitors 0.33uf and 0.1uF are 35V, 50V or higher I should be fine.
I attached my full notes including measurement data as pdf.
I measured the supply voltage with my scope in the following situations:
- original fan;
- original fan +200 uF (two SMD solidstate 25V 100uF capacitors https://www.lcsc.com/product-detail/Solid-Capacitors_AISHI-Aihua-Group-SVZ1EM101E06E00RAXXX_C320569.html)
- fan controller without fan
- fan controller without fan +200 uF
- fan controller with fan (ID-COOLING NO-8010-PWM)
- fan controller with fan (ID-COOLING NO-8010-PWM) + 200uF
again another quick project that took way longer then expected  |O  :blah:
« Last Edit: March 01, 2024, 01:35:57 pm by littleboot »
The following users thanked this post: jewelie
Offline jewelie
  • Everyone's gotta start somewhere
    • Personal website, of sorts, sometimes with a Pi-driven bird-feeder webcam (currently down but will be putting it up again in the near future with IR capability.)
« Reply #59 on: April 27, 2024, 10:33:51 pm »
For reference the attached photos are of the Tenma 72-10480 I got from CPC Farnell late in 2022 ( https://cpc.farnell.com/tenma/72-10480/power-supply-1ch-30v-3a-adjustable/dp/IN06822 ) which is clearly a rebadged KA3003.
I had a noisy fan issue that went away with a 25V 220uF electrolytic (poked deep into the connector, which is a bit hacky but it fits nice and tightly.)
It's clear the fan doesn't cope that well with PWM.
Oddly, with the capacitor, the fan runs faster at "full" loaded speed, which seems odd, unless the output isn't actually DC when at full speed?
Excepting the risk of it falling out (which seems minimal, plus I can see it through the vents at the side) is it safe/okay to be using this 220uF cap like this?
(If you'd like a laugh... whilst experimenting with the capacitor and fan I forgot to watch the 10R power resistor which I was only intending to misuse as a 90W heater for a few moments... I was only alerted by the magic smoke coming from the melting plastic box it was slowly sinking in to. :scared: Cue quick transfer to emergency containment pie dish. FFS!  :-DD)
EDIT:  Oh I see.  It's not actually a 12V peak fan control output then but actually higher?  So "full" speed isn't DC then, that'll be why the original fan still gets improvement from the cap even at full speed.  Does that mean I need a 35V cap rather than 25V for more safety margin?
« Last Edit: April 27, 2024, 10:58:42 pm by jewelie »
Anxious newbie to EEVblog.  Resuming an interest in basic electronics after a close shave with a joint EE/Computing degree decades ago
