Quote from: ceut on April 07, 2020, 08:56:02 amThank you for your feedback with your working unit.Do you have the 4.1 version of the PC utility (and maybe you can share it)? Thanks youMy Korad came with KEL103 assistant v1.2.1 that is not working over the network (because of the broadcast to 255.255.255.255 issue). Could you share your v4.0 software? It is probably much better that this.Thanks!
Can anyone tell me the distance between the binding post centres for this unit? What is the diameter of the posts?
