Author Topic: Korad kel 103 electronic load - timer in battery mode  (Read 1189 times)
Offline masterx81Topic starter
« on: June 01, 2020, 04:15:39 pm »
Hi! I have a kel103 as electronic load. I'm using it (also) as battery discharger, but i've noticed that the timer (down/sx display) is not in seconds. The setting of "timeout" in the manual is in seconds (and must be referred to that display). So, it's only my unit that count too fast, or it's a general issue?
Offline ArturP
Re: Korad kel 103 electronic load - timer in battery mode
« Reply #1 on: December 26, 2020, 08:33:37 pm »
I am not sure if you still need an answer to this, but the display shows the time in minutes (decimal representation). The setting is indeed in seconds, but display in minutes, go figure  ;)
« Reply #2 on: December 26, 2020, 09:29:25 pm »
Yeah, after a while i've figured it out. But why decimal??
