Author Topic: Korg NTS-2 4 Channel 'scope kit  (Read 1433 times)
Offline Andrew_DebbieTopic starter
« on: April 17, 2023, 02:36:27 pm »
Korg are selling a small 4 channel Oscilloscope kit.   It also has a spectrum analyser, a 2 channel signal generator and a musicians tuner.  Korg is a musical instrument company after all.
At $165/£165 it is a bit too expensive for a small ± audio bandwith 'scope.      After all ~£30 more will buy you a Hantek DSO-2C10 or similar.
Still, I find it an interesting concept worth a look.   Based on YouTube reviews, it is a lot better then JYE DSO-138 / 150 type budget scopes.
The no-solder kit is a based on a snap-apart screw-together PCB.   The case is white FR-4 with aluminum side profiles.  Once screwed together the scope is about 5"x3".
I'm sure it won't be long before clones turn up on AE.
https://www.korg.co.uk/products/nts-2
« Last Edit: April 18, 2023, 08:10:41 am by Andrew_Debbie »
Offline coromonadalix
Re: Korg NTS-2 4 Channel 'scope kit
« Reply #1 on: April 17, 2023, 03:11:13 pm »
Meh   not even capable to put some basic specs ........   let it go   and buy an  Hantek  even if they are basic ....
« Reply #2 on: April 17, 2023, 06:46:42 pm »
I'm not going to buy one. I'm not a muscian.  I  thought it was an interesting design.    I could see a something similar being done as a inexpensive open source project, maybe with more general purpose feature set.
 The features are targeted at somone with a modular or semi-modular synth. Even the AWG is as much about music as troublshooting.
This  is a good revew / demo of what it can do:
https://youtu.be/A_LtC6HI5YI
« Last Edit: April 17, 2023, 06:58:08 pm by Andrew_Debbie »
« Reply #3 on: April 17, 2023, 11:37:23 pm »
Well have to admit, impressed a bit, there is more videos of it on youtube ...
dont like the encoder shaft left like this, i haven't seen a knob ??
Offline dobsonr741
« Reply #4 on: April 18, 2023, 12:35:50 am »
Korg is not selling an oscilloscope kit. It’s a kit, happens to have a limited audio waveform oriented scope function. It will not be any use as a bench scope. For one, it won’t work for DC.
Offline themadhippy
« Reply #5 on: April 18, 2023, 12:42:46 am »
If it was in a more road proof case i'd be seriously tempted
did you watch the video?
Online Someone
    • send complaints here
« Reply #6 on: April 18, 2023, 12:48:04 am »
Korg's name for the product is "oscilloscope kit" and  oscilloscope is printed right there on the front panel. Just because it's targeted to a different domain doesn't make it any less of an oscilloscope. The specifications include DC coupling.
Offline dobsonr741
« Reply #7 on: April 18, 2023, 01:56:59 am »
You are right, I did not watch the video. I have an NTS-1. Still, my opinion is this device would only be serving a very limited audio frequency range. If you are an experimenting EE type, and not an Eurorack addict you will/should grow out of it very quickly. We should be discussing it in the Beginners board, not in the Test Equipments.
« Last Edit: April 18, 2023, 01:58:56 am by dobsonr741 »
« Reply #8 on: April 18, 2023, 08:33:25 am »
The DC coupling is useful for looking at slow  CV(control voltage) and gate waveforms.    Also good for general trouble shooting, since your ears can't might not hear a DC offset.
The snap-apart, screw-together kit is great industrial design. The Korg NTS-1 synth features similar construction.  I've never seen anything like it in a commercial product.
Structural FR-4 occasionaly turns up in open source projects.  I've done a few, for example  https://github.com/AndrewFischer/YamPlate
« Last Edit: April 18, 2023, 08:36:03 am by Andrew_Debbie »
