Author Topic: KP-184 Carrying case  (Read 241 times)
Online SpecialK
« on: May 17, 2021, 09:35:30 pm »
I'm enjoying my KP-184 electronic load very much.  However, I would like to take it out in the field and test 48V UPS battery packs at field locations.  I have a more portable BK Precision 601B, but it only tests 6V & 12V batteries.
I think I could put a handle on the top of the unit, but the power cord and test leads would need to be carried loose or in an attached pouch. I'm thinking I should be able to get some sort of carrying case.  A leather one would be cool, but I'm think a resin plastic one might be much more available.  A Pelican is probably overkill.
What is the term I should be searching? Tool box, plastic tote, ammo box, field box?  Any recommendations?
Offline duckduck
  • 20Hz < fun < 20kHz
Re: KP-184 Carrying case
« Reply #1 on: May 17, 2021, 11:17:38 pm »
Try "airtight case" or "waterproof case". There are tons on Aliexpress. I know that Harbor Freight Tools in the USA sells cheaper Pelican knockoff cases. I don't know if that helps you in Canada.
Online SpecialK
« Reply #2 on: May 17, 2021, 11:41:24 pm »
I will give that a try.  In the meantime, I found a small piece of luggage my wife has never used.  It says it's a tote bag(I think that's incorrect) and it's a nice size.  Has a separate zippered compartment I can keep cables in which should keep the perspex from getting scratched.  I might make a foam to slip over the front connectors and guard them from bumping.  Good enough for the trunk of the car. Boot of the ute, or whatever the bogans call it.
