I've got a Kunkin KP184 PCB version 3.0 which has a funny response in the mA range right out of the box.
The issue is that its measurement has a constant offset of 10mA.
Starting at 10mA I get no reading at all on my meter.
With the load set at 20mA I see 10mA, when load is set at 30mA I get 20mA, at 40mA I see 30mA etc.
Is this a calibration issue?
Or something else might be at fault?
Calibration procedure is pretty straightforward but requires a 25A current source which I don't have so I can't really proceed with it..
I've attached a picture of the problem.
With the load set to draw say 110mA I only see the 100..
This happens all the way down to 20mA.
At the 10mA there is no current draw from the load.
