+1
Some tests who are done with an meter may not be good at all, an good lcr meter will have an serial and or an parallel mode to test ''in circuit'' capacitor or inductances, sure it can measure an resistor too
it can help pinpoint a few things BUT for better results, you alway have to remove the part from the board, many things can affect the ''read'' values
EX: working in smps psu's, they are design to work with frequencies, not in pure DC / linear mode, sometimes you tests a few things and they appear as shorts, but when under a normal functionning mode they are okay ....
Same for other electronic equipment, it can vary a lot
