Author Topic: LCR Meter To Measure Smd components  (Read 1448 times)
Offline elefurtronikTopic starter
« on: April 21, 2023, 11:19:53 am »
Hello,
I am looking for a very good quality LCR meter. I will use it to measure smd components especially the capacitors on the circuit.
Please suggest me some LCR meters.  :-DMM
Offline Grandchuck
Re: LCR Meter To Measure Smd components
« Reply #1 on: April 21, 2023, 11:25:38 am »
Shannon tweezers are very good.  Long thread here about them.
Online Psi
« Reply #2 on: April 21, 2023, 11:27:59 am »
Hello,
Are you sure you want an LCR meter and not an ESR meter?
Some can do both but best to know what you want/need exactly.
« Reply #3 on: April 21, 2023, 11:41:41 am »
Hello,
I have a PCB and there are capacitors on it and I would like to measure their values with LCR meter. I think LCR meters can also show ESR value of the capacitor.
Offline pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
« Reply #5 on: April 21, 2023, 12:20:14 pm »
Thank you.  I will check this device but it seems I can only measure the caps up to 40V. Or what is dc bias up to 40V?
Offline pdenisowski
« Reply #6 on: April 21, 2023, 02:05:51 pm »
The LCX can provide an external DC bias up to 40V (or an internally generated bias up to 10V).  This is "added" to the test signal voltage, which has a frequency-dependent max value (but always < 10V)
If you need to test caps at higher voltages, then the only thing we could offer is scopes and power supplies.
Offline coromonadalix
« Reply #7 on: April 21, 2023, 02:57:26 pm »
Don't forget
Testing caps in circuit has a limit, you may be influenced by other parts / circuit   .... it as its limits
When you test some supplies    or very low output impedance stuff, it get problematic,   better remove the parts   ...
Done a few tests with the DE-5000  lcr in circuit and outside,  and results differ greatly ....
my 2 cents
The following users thanked this post: pdenisowski
