Author Topic: LCR-T7 Tester no longer switching ON  (Read 14182 times)
Offline SatbeginnerTopic starter
  • Dutch, early retired, living in Spain
« on: August 02, 2018, 08:49:15 am »
Hi all,
I have one of these Chinese LCR T7 testers (the one with build in LiIon battery and ability to test Zener diodes up to 30V), but suddenly it will no longer switch on.
Thinking of a bad contact, I opened it up, but it all seems in order, except....
There is a 6-pin SMD component next to the small, yellow transformer that is very hot when I try to switch it on.
I suppose this is the Step-Up thingy for the High(er) Voltage Zener test?
As far as I can see it is marked as U5, being an AL718, but I cannot find any data on this thing?
Question: Is there a schema / diagram available for this type of tester showing what type of chip this is?
Thanks for any response,
Un saludo,
Leo
You need a scope to repair a scope, and you need many multimeters to repair another multimeter!
*Tek 2467B, Tek 2465B, Tek 2465B, Tek 485, Tek 475A,  Keithley 175A, Keithley 2000, HP 3468B, HP 3457A, HP 34401A, PM 6671, PM 5716, Fluke 45, Fluke 75, Fluke 77, Fluke 79, AFX 9660BL, KPS 605D, etc. *
Re: LCR-T7 Tester no longer switching ON
« Reply #1 on: August 02, 2018, 09:14:31 am »
Hi all,
on a Russian site I ust found a possible substitute: http://monitor.net.ru/forum/dc-dc-stepup-info-629278.html
They suggest the ALxxx indicates it is a SD6271: https://datasheetspdf.com/pdf-file/1098029/SHOUDING/SD6271/1
At least it has the ALxxx markings, and it is a Switch mode Step-Up chip.
I will now see if the connections make some sense, like Vin, Enable, Switch-out, feedback, etc.
Although the datasheet says it goes to 24V out only, maybe in the T7 they used the transformer to get a higher Zener test voltage than that?
To be continued,
Leo
Online indman
  • Country: by
« Reply #2 on: August 02, 2018, 03:10:06 pm »
Read this subject from the very beginning, it will help you to find malfunction. :D
The schematic LCR-TC1 and LCR-TC7 coincide, except for some details.
https://www.eevblog.com/forum/testgear/tc1-lcr-meter-transistor-tester-fix/msg1622248/#msg1622248
The following users thanked this post: Satbeginner
Offline ahmad_hodrob
  • Country: jo
« Reply #3 on: August 12, 2018, 12:22:22 pm »
dear Sir,
kindly note that I have T7 transistor tester that suddenly stopped working ( no display) upon checking i found that C11 is shorted I replaced it with a 10uf capacitor, know the device is working but it doesn't go to calibration mode even when I connect a 3 short wires to it,even more  it reads the short wires as a resistors with a value of about 11 M ohm.
please I need an advice and if anybody can help me with the software of the unit.
Ahmad_hadrab
« Reply #4 on: September 15, 2018, 11:05:56 am »
sorry for my (very!!) late response, but I was waiting for the Switching IC (Type ALxxx) from China.
Today they finally arrived, but, after replacing it, it still would not switch on.
Long story short, one of the C11 / C12 capacitors developed a short, the remaining one measured around 5n6, so I removed both and replaced them with a 15nF capacitor.
It's back working again.
Thanks for the tip about the schematics, I don't understand why I did not found this before.... :palm: :palm:
Un saludo,
Leo
Offline madires
  • A qualified hobbyist ;)
« Reply #5 on: September 15, 2018, 01:45:43 pm »
15nF isn't suitable. A low-ESR electrolytic about 10µF or 22µF and 100V (>=63V) would be much better. It's the filter cap for the 50V DC used for checking Zener diodes. The original MLCCs are borderline because of the maximum voltage rating available for that package size (4.7µF) and the DC bias capacitance derating (known MLCC issue).
Offline nitesurfer
  • Country: ph
« Reply #6 on: July 15, 2019, 09:12:13 am »
Hello , just new to this forum, just wanted to thank you for the information on T7 LRC repair, Had one unit From a chinese supplier, the unit named TC1 but found that the printed board same as the picture you posted as T7, the unit just suddenly not powering on, through your post got the C10 smd capacitor and tested open line (OL) on the multitester, got it working with replacement of a 10nf smd capacitor, many thanks though the cost of the tester is not much, time of order of the tester on my location will take almost 45 days. :-+ :-+ :-+
Offline Robertr
  • Country: th
« Reply #7 on: January 26, 2020, 06:56:49 am »
I tried to measure a 9 volt battery with a T7, now it won't turn on. (smile don't do that). I've checked all the diodes, resistors and capacitors already mentioned. Anyone have any suggestion of what I likely popped?  Please and thank you in advance.
I feel bloody stupid over this and stubbornly want to fix it.
Offline madires
« Reply #8 on: January 26, 2020, 02:39:59 pm »
Did you measure the battery via the standard test pins 1-3 or the test pins for the Zener check A & K?
Offline Matt@TYGA
« Reply #9 on: June 06, 2022, 06:47:20 pm »
Hi guys
Just bought a T7 tester. But it won't calibrate. Short pins 1,2 & 3 with the cheesy thing supplied and it just shows a restance of around 0.25 ohms. Can anything be done?
Offline madires
« Reply #10 on: June 07, 2022, 09:26:24 am »
You could try to wiggle the short-circuit-thing to get a better contact or try a short wire instead.
Offline Hruki
  • Country: si
« Reply #11 on: December 05, 2024, 12:29:08 pm »
Hi Guys,
I have this new generation T7 tester, no longer turns on :(
I'm trying to investigate which component went wrong.
Do we have any schematic for this type? I attach two photos.
Thanks in advance!
Ruki
Offline madires
« Reply #12 on: December 05, 2024, 12:44:27 pm »
Your T7's MCU is an LGT8F328, not an ATmega. If you need to replace the MCU you won't get a firmware.
Offline Hruki
  • Country: si
« Reply #13 on: December 07, 2024, 08:04:25 pm »
I hope the problem is not with the uC. I'd like to test the other components first, that's why I need the schematic diagram.
Offline Harry_22
« Reply #14 on: December 09, 2024, 01:03:50 am »
Check the power at MCU first.
