Author Topic: LCR TC1 FIX BY REPLACING ATMEGA324PA AND REFIT FIRMWARE  (Read 677 times)
Offline nnannosTopic starter
« on: December 22, 2024, 09:47:17 am »
Hello, I have the lcr tc1(from banggood) and I put 12v ac to measure in pins 1,3 so now the pin 3 is not working, from the schematic seems that pin 3 goes throuugh a transistor into atmega324pa so I have to replace the Atmega324pa. What is the procedure to reprogram the atmega324pa? I have the stk500 programmer can i solder the atmega on the tc1 and then fit the firmware with stk500?
Thank you in advance
Online madires
  • A qualified hobbyist ;)
Re: LCR TC1 FIX BY REPLACING ATMEGA324PA AND REFIT FIRMWARE
« Reply #1 on: December 22, 2024, 10:11:12 am »
There are several versions of the TC1. Could you please post pictures of the PCB's front and back side?
« Reply #2 on: December 22, 2024, 11:15:48 am »
Here are some pics(It has atmega324pa-au as U1 main processor and as U4 stc 15w104, also noticed the DZ2 chip srv05-04 has issue between pins 3,4(the diode is burnt)
« Last Edit: December 22, 2024, 11:18:52 am by nnannos »
Online madires
« Reply #3 on: December 22, 2024, 11:59:41 am »
DZ1 and DZ2 are used as input protection. You can remove both and check again. Your tester is one of the early versions with an additional control MCU (U4). If you want to replace the ATmega you need to go for one of the OSHW firmwares and also take care about U4. Either you reprogram U4 (https://github.com/atar-axis/tc1-u4) or replace it with a simple circuit (https://github.com/madires/Transistortester-Warehouse/blob/master/Hardware/TC1-Mod.pdf).
« Reply #4 on: December 25, 2024, 12:36:13 am »
Hi again, although I managed to program the U4, I have issues on programming the U1 ic. I try to make the file before uploading and I get this:
avr-gcc -mmcu=atmega324p -Wall -I. -Ibitmaps -DF_CPU=16000000UL -DOSC_STARTUP=16384 -gdwarf-2 -std=gnu99 -Os -mcall-prologues -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -MD -MP -MT main.o -MF dep/main.o.d -c main.c
In file included from config.h:1646:0,
                 from main.c:24:
config_support.h:100:4: σφάλμα: #error <<< No display module enabled! >>>
make: *** [Makefile:226: main.o] Error 1
Any idea why?
Online madires
« Reply #5 on: December 25, 2024, 11:08:15 am »
Because no display module is configured?
« Reply #6 on: December 25, 2024, 10:18:46 pm »
Managed to upload a ready compiled firmware(Markus) but keeps recycling in metering(shows the value of part the shows battery voltage and again the same, without pressing the button to measure. Is this how this firmware works or is there an issue on my device?
Online madires
« Reply #7 on: December 26, 2024, 09:05:13 am »
Works as intented. From the README:
* Power-On
A long key press while starting the tester selects the auto-hold mode. In that
mode the tester waits for a short key press after displaying a result before
it will continue. Otherwise the tester chooses the continuous (looping) mode by
default. You can reverse the operation mode selection in config.h (UI_AUTOHOLD).
+ Test Key
The test key starts the tester and also controls the user interface. For that
purpose the tester differentiates between a short and a long key press (0.3 s).
« Reply #8 on: December 30, 2024, 07:40:53 am »
What is the procedure to create the hex and eep files from the m-firmware 1.54? In the make file I have to suggest the tool and I do not understand why the tool is critical(I use the stk500 for uploading using ISP port). So what is the procedure to compile and create the files?
Online madires
« Reply #9 on: December 30, 2024, 09:26:04 am »
Please see https://github.com/madires/Transistortester-Warehouse/tree/master/Documentation/English. You'll need an AVR C compiler plus toolchain.
