Author Topic: LCR Tweezer Fnirsi ST1 vs. Zoyi MD1  (Read 18723 times)
Offline mawyatt
Re: LCR Tweezer Fnirsi ST1 vs. Zoyi MD1
« Reply #50 on: October 09, 2024, 01:39:20 pm »
I apologize - I did not mean to be misleading! I actually earned my PhD 24 years ago, but in the humanities; I teach / serve as a Dean at Campbell University in central North Carolina. The university has a relatively new (~10 years old) School of Engineering, and I am finally getting a chance to fulfill a long-standing desire to sit in on a circuits class. Despite my professional focus on the humanities, I have been tinkering with designing / building circuits for 40+ years, and while I have generally succeeded in building something that works, I have always been painfully aware of how much I am "guessing" at design choices or at values to use (e.g., for a simple RC filter to quiet the bounce on a mechanical switch). Or as I often say, I have worked by trial and lots of error. :) Thus far, the class has been extremely enjoyable and has already filled in quite a few of the gaping holes in my knowledge. And this forum is adding to my knowledge as well!
That must be fun to sit in on an area you are interesting in learning about :-+
Electronics is fascinating, has been for us for almost 7 decades ;)
If you are interesting in better understanding of things try approaching from a fundamentals standpoint. Learn the basics in detail, then proceed with the application of such.
It lots of fun to sketch out a simple circuit on the back of an envelope, write a few equations, note some bias voltages/currents and waveforms. Then build on a protoboard and have it work 1st time without resorting to Google or LTspice, just pen, paper and trusty old HP calculator ;)
It's also fun being around young minds, you can spot the potential stars. When an Adjunct creating and teaching 1st advanced graduate classes in RFIC design we spotted those students and hired them (inside advantage)  :-+
Best
« Last Edit: October 09, 2024, 02:58:56 pm by mawyatt »
~Wyatt Labs by Mike~
Offline awakephd
« Reply #51 on: October 10, 2024, 03:36:01 pm »
It has been very fun! With the professor's permission, I have been doing all of the work - homework, labs, quizzes, exams - it has been a great reminder to be on the student side of things. As dean, I oversee a graduate/professional program, and nearly all of our students are working significant hours, many with full-time jobs, families, and life responsibilities. I am planning to recommend to my faculty that they look for a class that they would sit in on, just to remember what it is like to be a student while juggling a full-time job.
Indeed! The course I am taking has proven to be "just right" in terms of what I already knew vs. what I need to learn. I have long been conversant with things such as Ohm's Law and the principles of how BJT and MOSFETs work. The class I am taking is more or less a "part two" class on circuits - the first class having introduced students to the things I have painfully learned (mostly) over many years. I was a bit concerned that my math skills would be too rusty; once upon a time I loved maths up through Calculus, but it has been many, many years since I have worked out a significant integral or derivative. So far, however, I am finding that what I have needed mathematically has come back quickly, and it has renewed my enjoyment of math. One thing that has been particularly interesting to observe is that often I know the practical implications / applications that the students know only in theory (and I may only now be learning the theory). For example, I've blown up more than my fair share of MOSFETs along the way, so when we discussed h-bridges and the problem of shoot-through, I could have testified!
Offline DaneLawTopic starter
« Reply #52 on: October 10, 2024, 06:33:38 pm »
In regards to the zero/relative-feature on Fnirsi ST1.
On lower values fx 10mOhm from traces' it seems to relative that value on top, every time you hit it, a power cycle will remove that offset.
Lookslike its adding the value.?
https://i.imgur.com/i7YdCIs.mp4
While on bigger values fx 100mOhm it does seem to null it.
Tried to zero it on 100mOhm res (before the video starts), and the corresponding reading does cycles down around 0mΩ
https://i.imgur.com/X6kHfFM.mp4
« Last Edit: May 01, 2025, 07:20:02 pm by DaneLaw »
Offline tigrr
Offline Paul T
  • Mechanical Integrity Design
« Reply #55 on: December 06, 2024, 11:03:16 am »
I now have both devices.  This past week I received a FNIRSI LCR-ST1 (v1.5 F/W).
I definitely like the ZOYI ZT-MD1 (v1.8 F/W) better.
Here's 10 reasons why.
(1) The FNIRSI wheel operation (pushing) has a flaky response, like a worn-out switch.  Almost have to use my fingernail to push it.  Maybe it should be set higher.
(2) The refresh rate is similar, but the ZOYI settles in to a stable value a little better, especially on resistance.
(3) Resistance < 0.5 ohms is way more accurate on ZOYI.  Seems that the ZOYI is closer to a true 4-wire setup.  The ST1's REL feature is not very helpful.
(4) Inductance < 50uH is consistently low on the FNIRSI.  Same 10kHz frequency.  Can't REL it out.
(5) Schottky diodes measure 0.50 on the FNIRSI, could be confused for a silicon diode.
(6) The FNIRSI tips are more easily misaligned when squeezing.
(7) Bigger lithium cell on ZOYI.  Battery life is fine, but why is it half?
(8 ) The FNIRSI charges at 340 mA, which is C = 1.36, battery life might be affected?
(9) The price is about 25% more from FNIRSI.
(10) The ZOYI is easier to read the screen due to font and size, less busy.
On the other hand, the FNIRSI LCR-ST1 has some things going for it:
(1) More comprehensive data logs.
(2) The gold plating on the tips was more durable for me (doesn't flake off at the tip).
(3) The FNIRSI and the carry case look a little nicer and more colorful.
(4) The screen protector is very clear and undamaged.  You can rip off the pull tab and leave it on.  The ZOYI screen protector is like thin food wrap.
(5) Only the ST1 has internal blade serrations, preventing radial lead components from rotating 90 degrees when squeezing onto the outside.
As a result, both sitting in front of me, I would definitely reach for the more accurate and easier-to-navigate ZOYI ZT-MD1 for most tests.
Maybe I would be more likely to show off the FNIRSI to a friend.  That's about it.
« Last Edit: December 10, 2024, 11:26:35 am by Paul T »
The following users thanked this post: giovannirat, jackobo, jebem, Aldo22
Offline Propretor
  • Country: ru
« Reply #56 on: April 30, 2025, 05:34:53 pm »
Even with firmware 1.6 in diode test mode, the reading on the screen must be divided by 1.41 to find out the true value of the diode voltage!
Smart people do not so much seek loneliness as avoid the fuss created by fools.  Arthur Schopenhauer.
Offline Paul T
« Reply #57 on: April 30, 2025, 05:38:21 pm »
Please provide a real case that leads you to this conclusion  :popcorn:
Offline Propretor
  • Country: ru
« Reply #58 on: April 30, 2025, 05:52:10 pm »
You can take any diode or Schottky diode, determine the voltage drop with a quality DC instrument, and then make similar measurements with the FNIRSI LCR-ST1. Divide the value that the FNIRSI LCR-ST1 shows by 1.41 and you get a value that is very close to the real value measured by a normal instrument. The explanation for this effect is very simple - the FNIRSI LCR-ST1 has no DC operation mode, and the developers forgot to divide the reading by 1.41 (SQR2). The actual, effective or RMS value of a harmonic signal is 1.41 (SQR2) times smaller than its amplitude. It's simple :)
The difference will only be due to the accuracy of the measurement and the different amount of current flowing.
The following users thanked this post: jebem
Offline Paul T
« Reply #59 on: April 30, 2025, 06:02:41 pm »
Thank your for the theory on this.  Since I have not encountered this error, could you show a real case?  Personally I have noticed the diode function lacks accuracy, but all the readings were lower not higher.
Offline jackobo
  • Country: ie
« Reply #60 on: May 09, 2025, 02:55:53 pm »
Lads, in the end of the day, which one to get to have some play Fnirsi or Zoyi? )) the price nowadays +- virtually the same.
Offline Paul T
« Reply #61 on: May 09, 2025, 02:58:46 pm »
I still feel the same as my detailed post several posts above.
« Reply #62 on: May 09, 2025, 04:10:03 pm »
I also lean on MD1 it's a tad more stable but the tips is also not as pointy as ST1.
Some things that ST1 got that the MD1 doesn't are selective secondary parameters.
On the ST1, you can push in the toggle switch with a long push, and jump between the secondary values on a given reading, Q, Z, X, D (from +20s https://tinyurl.com/mty2ye5k )
The back is also magnetic on the ST1.. Easy to hang on anything metal (there is a small metal sticker-sheet incl. to hang it at any given place of choice).
Got 3 of these budget LCR Kelvin AC tweezers.
*QP-LINK 1S, *Zoyi MD1 and *Fnirsi ST1 "side by side" to give an idea of the size.
QP 1S is quite a bit more expensive, and it shows in the alu build & design. It's more than double in price at $48 delivered (incl. 25% EUVAT/DK), but it also got more features... like a 0.1 V test mode, which can be quite useful for keeping semiconductor junctions off, avoiding latch-up, or damaging fragile ICs, while also reducing core saturation in small inductors and preventing inaccurate or false readings in nonlinear or sensitive components, like ceramic capacitors or high-impedance parts.
It’s also worth noting that the QP LCR 1S has a 100 kHz measurement mode that, alongside 0.1V, can help highlight parasitic effects & frequency-dependent characteristics, which could be useful in real-world high-speed or analog designs.. QP-1S also got a 120 Hz mode, which neither MD1 nor ST1 has.
That can be handy for checking parts used in full-wave rectified 60 Hz power supplies, like electrolytic capacitors and other power components, since it reflects real-world conditions like AC ripple & line frequency, it can help you get more accurate readings of capacitance and ESR..Especially in power, audio, and low-frequency magnetic circuits.
QP-LCR LINK1S will also will do/measure DC voltage which I personally find handy to have in a small LCR tweezer, up to around a max of 16V* (if I recall correctly*) and it support higher tolerances like 10.000 count across the full range and it got an accelerometer that will flip the display according to your orientation, or you can user-select in the menu, but it could be that QP LCR 1S is out of production here in 2025, as very few listings last time I checked and prices were significant higher, so perhaps down to "old stock".
// QP LCR1S not being produced anymore, so possible fw upgrades is more or less out with the bathwater, even though it got built-in menus for fw upgrades.
Zoyi MD1 got the biggest gap of the three tweezers (highlighted below)
QP LINK 1S - Zoyi MD1 - Fnirsi ST1
« Last Edit: June 19, 2025, 10:26:07 pm by DaneLaw »
The following users thanked this post: jackobo, jebem
Offline jackobo
  • Country: ie
« Reply #63 on: May 10, 2025, 05:29:59 pm »
dont need them two Fnirsi and Zoyi MD1 or even 3 including QP. Just ordered ZT-DQ02. In addition to it having a hard choice between Fnirsi and MD1 tweezers, to play with. Should I better flip the coin? :-//
« Reply #64 on: May 11, 2025, 05:45:23 pm »
A tad conflicting, as in if you don't need an LCR tweezer, then don't get it.
Wait for your Zoyi DQ02 and be familiar with that, and see if it will saturate your needs.
Offline jebem
  • Country: pt
« Reply #65 on: June 14, 2025, 03:47:52 pm »
After reading several threads here, I have ordered two new LCR meters from ZOYI to join my humble cheap PROSTER BM4070 LCR Meter.
So they are the ZT-DQ02 handheld model and the ZT-MD1 tweezer model.
Although I would like to have a few more of these tweezer models like the Fnirsi  ST1, not to mention the Aneng gn702 or the 3S QPL LCR Tweezer.
All of them are in my AliExpress's Cart for further consideration.
But concerning the models in discussion here:
Using the published pictures and videos, it can be seen that the ZOYI ZT-MD1 circuit uses SD03 TVS diodes, one per input leg of the tweezers.
They are marked as 03W in the diode package, and most probably are supplied by Leiditech.
Being protection devices, the SD03 TVS diodes will conduct when the applied voltage is above 3.3V. Below that value they will exhibit very low leakage current in the nA region.
While the usage of TVS diodes is a standard choice as a protection against electrostatic or surge voltage, usually two of these diodes are use in parallel.
Here in the MD1 only one diode is used. This looks to be a less than optimal solution.
What do you think?
Offline jebem
  • Country: pt
« Reply #66 on: June 14, 2025, 04:15:58 pm »
Get both the handheld and the tweezer models.
The ZT-DQ02 handheld model gives better results and features, but is not supplied with tweezer probes for SMD testing. These need to be acquired elsewhere and I believe they are expensive if quality is required.
The ZT-MD1 is much more convenient in use for SMD PCBs, no attached cables, having enough precision for regular work.
So both have a place in the workbench.
Also it is convenient to have more than one meter of any kind, to compare readings when in doubt or when one fails to work.
Offline donwulff
« Reply #67 on: June 18, 2025, 11:24:51 pm »
Noticing a pattern where a thread starts about some FNIRSI product, then it becomes recommendations for other brands instead, haha. Anyway, did the stupid thing with my LCR-ST1 and after measuring PSU main cap with multimeter and finding it flat, used the LCR-ST1 to measure the parameters... oops, that wasn't flat at all, just solder oxidization!
Basically, this is one good reason to look for the cheapest instruments, if you ever suspect something like this could happen for you, even (or especially) if you do have more expensive instruments where it matters. Anyway, I immediately ordered new LCR-ST1, ANENG GN702 (Which looks identical to the "Zoyi MD1" in this thread) and even FNIRSI LCR-P1, which hasn't arrived yet, though based on the thread on it they can't even get the diode direction right? First impressions are that ANENG doesn't auto-identify diodes, and when you manually select diode-range, it's appears showing fixed 0.5V forward drop, which the manual seems to be hinting at with "The product's diode forward voltage measurement value is for reference comparison only, with measurement range of Vf 0.1V~0.6V. Values beyond this range will display "OL." For higher measurement requirements, select a more professional diode measurement instrument." (Emphasis mine).
ESR measurements are also highly differing between the FNIRSI and ANENG on the 100Hz and 10KHz ranges. On the other hand, the ANENG has resistance calibration, if you have 1 to 10M ohm precision resistors at powers of ten... Due to the frequency dependency, I don't think that'll be useful. I might make a closer comparison if I have time, but FNIRSI feels like the clear winner here despite the slightly higher price of ANENG.
Back on the topic of the FNIRSI capacitor-mishap; the the GS8632-MR OpAmp in the input stage visually blew up, the PGA112AIDGSR Zerø-Drift Programmable Gain Amplifier and ARTERY AT32F403ACGU7 MCU shorted internally. Since they're all relatively cheap components, I wanted to see if I can still revive it... however, FNIRSI only providers that drag & drop BIN update, and it turns out the ARTERY chip is read-protected checking on the replacement I bought. And no, it doesn't unlock when putting it into firmware update mode, already checked. I had a genuine problem trying to upgrade the firmware (It got stuck in firmware upgrade mode without the USB port enumerating), so I shot FNIRSI's info email address a question if I could have the full flash image to program with SWD (Worth a shot!) but they didn't respond at all.
The firmware upgrade worked after the battery ran flat and it reset, though the new replacement chip doesn't have the bootloader. So does anybody have a full firmware image, or knowledge if the upgrade BIN image could be used somehow by its own?
« Last Edit: June 18, 2025, 11:37:05 pm by donwulff »
Offline skrickis
  • Country: lv
« Reply #68 on: December 05, 2025, 05:43:05 pm »
Hello colleagues!
Could someone measure the Finirsi ST-1, what should be the nominal resistances
in the picture marked with yellow 1.-3. these are completely burnt out.
I replaced the operational amplifiers and analog switches.
And I'm not sure if the red ones from 4.-11. have the right resistance.
Unfortunately, I did not fully discharge the capacitor and this resistance burned
Currently I soldered 100 ohms and the resistance is measured accurately with " *1000".
« Last Edit: December 05, 2025, 07:08:58 pm by skrickis »
