Author Topic: LCRZ Meters, Chart ?  (Read 3282 times)
Online Randy222Topic starter
« on: December 29, 2023, 03:16:32 pm »
Is there on EEVb a chart that lists out the relatively good LCR meters using community feedback, in a chart or the like?
I just trying to get a sense of what meters are better than others, and for what reasons, like "best value", "most accurate", "better precision", "better resolution", etc.
Online KungFuJosh
  • TEAS is real.
Re: LCRZ Meters, Chart ?
« Reply #1 on: December 29, 2023, 04:17:07 pm »
I haven't seen one.
The short list is:
DE-5000 - accurate / best value / handheld meter
TH2830 or 2832 / ST2830 or 2832 - Best lowish cost lab grade bench meters (Tonghui TH is terrible support, SourceTronic ST has excellent support).
Hioki IM3536 - excellent lab grade bench meter.
Instek LCR-8200 series - very expensive lab grade / high frequency meters.
There's also some less reliable, but usable bench meters from East Tester.
Offline coromonadalix
« Reply #2 on: December 29, 2023, 04:32:48 pm »
I haven't seen one.
The short list is:
the DE-5000  is built around 2 ic's,  Mastech  lcr as them, Uni-t  old series,  and other clones
now  maybe in the middle range
Many of the ET-430 and up models, new Uni-T
Hantek 1832 1833
100khz  is a basic requirement  nowadays
and i hope  you discern precision vs resolution ...
« Reply #3 on: December 29, 2023, 05:58:09 pm »
100%. I am well versed with accuracy vs precision vs resolution. They are 3 terms often not understood.
Now I go lool at the various listed models.
The following users thanked this post: coromonadalix
« Reply #4 on: December 29, 2023, 06:03:05 pm »
really depend of your need
serial parallel   ecr dcr   etc ....   resolution 20000 40000 counts
interfacing
lots of portables one if not all, dont do supplemental DC biais voltages,  just the bench ones
or need special cases  like sencore lc102 lc103   who will really do 1kv tests ???  they are the only ones at an astonishing price
even thoses  little component tester can do wonders ... 20$ is not excessive, Fw Hw support
and only some of the high ends will discharge the caps before measurements, all the portables low medium costs  will bust, even some middle high end ones  etc ...
« Last Edit: December 29, 2023, 06:06:25 pm by coromonadalix »
« Reply #5 on: December 29, 2023, 06:09:03 pm »
Basic handheld is my needs.
I am replacing an old made-in-taiwan "SCOPE LCR 680".
2023, time for an upgrade.
Is this a legit seller at this price? ET432 for $142US ? Are there counterfeits of the ET43's labled as ET43's I need to look out for?
https://www.aliexpress.us/item/3256804318991185.htm
Online csuhi17
  • Country: hu
« Reply #6 on: December 29, 2023, 06:13:39 pm »
I've seen few tests about it, but the accuracy of the ET430 was not good in those.
maybe Uni-t is better, but I haven't seen a video about it yet.
Fnirsi oscilloscope = waste&regret
« Reply #7 on: December 29, 2023, 08:51:30 pm »
I looked at the latest Uni-T 612, but the specs seem odd. R has a range of 20-200M. 20 ohms is the lowest it can read? Doesn't make sense to me.
On my old Scope 680, R is not R at all, it's really Z. L C & R all run at 1kHz. So if you wanted DC ohms from just a resistor, the reading might be off, because it's really Z.
Are the "LCR" handhelds today all LCRZ? I would like LCRZ because with some Rf work it's good to be abe to measure LCZ and real DC R.
GwInstek LCR-1100 looks ok from the spec sheet, just can't find much about it, or where to buy.
I have a GwInstek signal gen, works ok.
« Last Edit: December 29, 2023, 09:01:56 pm by Randy222 »
Online Martin72
  • Testfield Technician
« Reply #8 on: December 29, 2023, 09:20:52 pm »
I agree with KungFuJosh, TongHui or Sourcetronic is the best you can get at an affordable price.
The workmanship, the accuracy, the features...
If you want more, you have to pay a lot more, we're talking about 4000€/$ upwards.
If you can live with 100khz (sorry, 200khz  ;) ), you won't find anything better, not even for more money (GWinstek, BK precision...).
The DE5000 was also mentioned, and I agree, you can't get more for the money.
The cheap desktop devices from East Tester are slightly better, but they are desktop devices and not portable.
(Kierkegaard)
« Reply #9 on: December 29, 2023, 11:06:22 pm »
Anyone use or have test data for a Tecpel lcr-615 ?
Can't seem to find any online sellers of this unit.
Online pope
« Reply #10 on: December 29, 2023, 11:58:57 pm »
I haven't seen one.
The short list is:
What makes you think that the ET meter is less reliable? I mean, it might well be the case but do you have some personal experience with these meters?
« Last Edit: December 30, 2023, 12:01:52 am by pope »
Offline Veteran68
« Reply #11 on: December 29, 2023, 11:59:15 pm »
As with most things you'll generally get what you pay for.
The DE-5000 is the goto for hobbyists on a budget, but it has its limitations. Namely in test parameters and user interface, which is pretty horrid. A step up would be the Hantek 183x series. I have the 1833C and like it okay. If I were buying another handheld LCR today in the ~$200 range I might go for the highest end Uni-T 622 model.
If you want a bench LCR, then you're looking at EastTester, RuoShui/Victor, and Matrix at the lower end but even those can run into the 300-500 range for the higher models.
As you get to Tonghui, Sourcetronic, and Hioki, then you're approaching if not exceeding $1000, depending on model.
And of course you can go with something like R&S for a couple more K.
« Reply #12 on: December 30, 2023, 12:20:27 am »
The Hantek units are in my budget. But I read a few reviews that said the unit was horribly not accurate. Maybe some bad apples coming out of the mill?
Online Martin72
« Reply #13 on: December 30, 2023, 12:27:35 am »
And your budget is ?
And what to prefer, handheld or desktop ?
Measure frequency up to ??
(Kierkegaard)
The following users thanked this post: egonotto, thm_w
Offline Veteran68
« Reply #14 on: December 30, 2023, 12:43:56 am »
Possibly. I've had a few measurements I've scratched my head at, which is why I said if I were buying again in that budget range I might choose something else. But if I'm honest most measurements I've done and compared against other meters (from 6.5 digit bench DMMs to cheap capacitor/ESR meters) it's been close enough to call it within expected range.
These things are so sensitive to test conditions and parameters that unless I knew exactly how a reviewer's test was setup, I'd take their results with a grain of salt. You can play around with the settings (test voltage, frequency, range, etc.) and get pretty vastly different results. Not to mention that some people insist on testing in-circuit and expect reliable readings.
« Reply #15 on: December 30, 2023, 01:09:01 am »
in circuit is a first general test / basic values check tests /  when having doubts, isolate or remove the part
for sure there is some limits, and surrounding parts may play tricks on you
an open and close calibration when available is a plus,
ex: i use an de-5000 at my job,  and each time i power it up, i do the open and close calibrations, and for sure, just moving the leads change values quite a bit  .... human body presence ...
i use some circuits while putting rf in it,  just being around it, play tricks   loll i can not use any serial or parallel tests, it will self oscillate the circuit
but with experience and many many archived tests, even with an ohmmeter now i know if a portion is defective   ...
The ET430 and up lcr meters are resold in many colors and brands,  not sure for their quality  ??? seems to have some decent circuitry  ???
Tonghui have some protables ones too, pricing seems high
Hioki
Applent / and rebranded ones
old BK Precision models like BK885 BK886
now we beggin to have ideas ...
Online KungFuJosh
  • TEAS is real.
« Reply #16 on: December 30, 2023, 01:33:53 am »
Search the forum, other users have stated as such. 🤷
« Reply #17 on: January 02, 2024, 02:25:51 pm »
I'll give the Hantexk 1833C a try. In my searching for the 1833C I also found a ZT-703S dual channel handheld scope.
Online csuhi17
  • Country: hu
« Reply #18 on: January 03, 2024, 08:28:51 am »
Does anyone have experience with the UNI-T UT622E, how reliable is it, is it better in terms of features than the Hantek?
If I see correctly, it is only slightly more expensive than the Hantek 1833C.
Online KungFuJosh
  • TEAS is real.
« Reply #19 on: January 03, 2024, 03:21:02 pm »
I think the general consensus is:
Almost Anything > Hantek
I have a few UNI-T devices that work fine; no LCRs from them though.
Offline Veteran68
« Reply #20 on: January 03, 2024, 03:36:30 pm »
I've seen a few reviews of the 622's and don't recall seeing a head-to-head comparison with the Hantek, but just observationally I thought the Uni-T looked like the better option. I wasn't aware of the 622 series when I bought the Hantek, if I had been I'd have probably got the 622E myself. Darren Walker reviewed the 622A some time ago, but most of the 622E video reviews I find are non-English and require translated captions, so I've not dived into those yet.
That said, the Hantek 1833C has worked fine for me so far, as I mentioned, so I have no real regrets other than I typically don't care for Hantek products. In that budget tier I definitely tend to favor Uni-T. Not that they're premium quality either, but to Josh's point almost anything is better than Hantek, generally speaking. I was actually leaning towards the defacto DER-5000 but saw enough favorable reviews of the 1833C and it's improvements over the DER that I decided to go with it. No regrets as I said, I'm just not exactly in love with it.
I posted my thoughts on Hantek in this thread asking about the 622E vs the DER-5000 and referenced Tony Albus' video that compared accuracy specs of the lower Hantek 1832C against higher end meters. It performed pretty well.
Offline Veteran68
« Reply #21 on: January 03, 2024, 03:40:41 pm »
I have both the ZT-702S and ZT-703S. Recognizing their shortcomings for what they are as a scope, they are an excellent value for the money IMO. Toss them in a toolbag to have a useful DMM and a low-bandwidth scope on the go, and if you break it you're not out much. Whereas I'm much more protective of my Owon HDS2022S.
Although the new ZT-703S that just came out has some FW regressions in my opinion, namely around restoring last mode at powerup which had already been addressed in the 702SS. Also consider their really useful bandwidth as about half of what is stated for each.
Online hpw
« Reply #22 on: January 03, 2024, 04:31:43 pm »
What me  >:D is each time to calibrate (open connection mode), specially the Cap as on startup 8pF off. As it do not gets saved even using last FW. After that 1pf SMD is possible to measure with the required fixture.
Anyway... for SMD parts a fixture is a must have and needs additional tweaking as cable and fixture. For more look on the good & ugly SMD fixture thread.
Hp
Offline HalFoster
« Reply #23 on: January 03, 2024, 04:55:34 pm »
For bench meters, I have both a Wayne Kerr 6425 and a Instek LCR6100 - both .05% class meters and I can highly recommend either one although the 6425 tends to be much easier to use although also much larger.  The DE5000 really can't be beat for hobbyist level equipment.
Hal
--- If it isn't broken... Fix it until it is ---
« Reply #24 on: January 03, 2024, 05:16:43 pm »
Hal
The high quality benchtop style are 5-10x the cost of the handheld units, perhaps for good reason, or perhaps the dollar-per-unit of accuracy & precision is just much higher on the better benchtop units. Finding a linear cost basis is almost unheard of these days. It's like double the accuracy & precision and pay 3x as much, etc.
I am replacing my old Scope LCR 680 handheld. So I am kinda comparing to what I have now, which means just about anything new today is likley way better than the 680.
If I needed something like Instek 6100, I would just buy something like that, but I think a "decent" handheld is all I need as of now.
Offline Veteran68
« Reply #25 on: January 03, 2024, 06:42:01 pm »
Hp
I think you'll find best practice with most LCR instruments is to calibrate before each use, especially a handheld unit that will be used in inconsistent locations or dynamic environments. As was mentioned, there's a lot of environmental influences at play in these measurements, especially with smaller values, so it's generally advisable to calibrate before every use anyway. I'm in the habit of doing so with my Hantek and it's not a problem. It's no different really than the practice of letting a device warmup to ensure best accuracy.
« Reply #26 on: January 03, 2024, 07:02:13 pm »
Hp
My test room is a small faraday cage.  :-DD
I joking, for me. But surely such is needed in certain testing environments, just like the various types of anechoic chambers.
« Last Edit: January 03, 2024, 07:04:00 pm by Randy222 »
Offline Messtechniker
« Reply #27 on: January 03, 2024, 08:12:59 pm »
Got an UT622E. Does all I need. Nice display.
Never had a LCR meter before, so I can't compare.
UT622A: 10 kHz max. No DCR
UT622C: 100 kHz max., No DCR
UT622E: 100 kHz max., DCR
The extra cost for the UT622E with DCR is probably not worth it.
So the UT622C would be the sweet spot here.
Agilent 34465A, Siglent SDG 2042X, Hameg HMO1022, R&S HMC 8043, Peaktech 2025A, Voltcraft VC 940, M-Audio Audiophile 192, R&S Psophometer UPGR, 3 Transistor Testers, DL4JAL Transistor Curve Tracer, UT622E LCR meter, UT216C AC/DC Clamp Meter
Offline alm
« Reply #28 on: January 04, 2024, 01:57:51 am »
I'd guess it's a combination of a more complicated design (no single chip solution), lower volume and different target market. But this has always been true. In the 1960s a differential voltmeter with 0.05% accuracy was also much more expensive than an analog Volt-Ohm-Meter with 1% accuracy.
