Author Topic: LD400P electronic load  (Read 708 times)
Offline FaringdonTopic starter
« on: December 06, 2022, 07:40:55 pm »
Does any body have a quik start guide or vid for this?
We searched but manual not that readable.
Just want to set basic constant resistance.
And make sure power limit is above 120W
'Perfection' is the enemy of 'perfectly satisfactory'
Offline thm_w
  • Non-expert
Re: LD400P electronic load
« Reply #1 on: December 06, 2022, 10:53:18 pm »
https://resources.aimtti.com/manuals/LD400+LD400P_Instruction_Manual-Iss4.pdf
Manual seems fairly readable to me. Has A and B level modes, and an enable.
From the main screen:
- Press the Mode softbutton, then select "CR" constant resistance.
- Press the Levels softbutton, set levels, or none to disable.
