Hello
I purchased a Hantek DSO5102B 3 weeks ago, it worked for 1 day and after that it never boot up. I guess it should be latest HW version as the UART location was on the back (comparing to pictures I saw for connecting the debug UART).
after connecting the UART to the PC, I get these messages:
*** Warning - bad CRC or NAND, using default environment
##### EmbedSky BIOS for SKY2416/TQ2416 #####
This Board: SDRAM is 64MB; LCD display size is: 800 X 480
Press Space key to Download Mode.!
SD:File System init failed!
Start Linux ...
NAND read: device 0 offset 0x300000, size 0x400000
4194304 bytes read: OK
Boot with zImage
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
which the kernel never starts. I think the zImage (kernel) is bad.
if i press space, before loading the kernel it goes to the download mode:
##### Boot for SKY2416/TQ2416 Main Menu #####
##### EmbedSky USB download mode #####
[1] Download u-boot or STEPLDR.nb1 or other bootloader to Nand Flash
[2] Download Eboot (eboot.nb0) to Nand Flash
[3] Download Linux Kernel (zImage.bin) to Nand Flash
[4] Download LOGO Picture (logo.bin) to Nand Flash
[5] Download UBIFS image (root.ubi) to Nand Flash
[6] Download YAFFS image (root.bin) to Nand Flash
[7] Download Program to SDRAM and Run it
[8] Boot the system
[9] Format the Nand Flash
[a] Download User Program
[n] Enter TFTP download mode menu
[r] Reboot u-boot
[t] Test Linux Image (zImage)
Enter your selection: 3
Now, Please connect to USB cable and USB interface!
the device is connected via USB to the PC. at this point the PC detects "EmbedSky TQ2416 Board" , which I dont have any driver for that.
highly appreciate any help , I need the USB driver and the zImage to see if it can work.
Thanks
Reza
