I bought an RD6006 several months ago and am using it to power an embedded computer in a parked vehicle.
I have it plugged into an extension cord and configured to turn on the output upon startup. The supply is set for 12V/3A and the embedded computer typically draws 6-700mA.
I have used this setup successfully for a while, turning it on/off by plugging or unplugging the extension cord into a receptacle on the outside of my house.
The past few times I've tried this it worked fine for some time (5-60 minutes) and then the output shut off (supply was still on). If I enabled the output, it again worked fine for some time and then the output was disabled again.
I'm using the recommended 60V supply and I do have the temp probe installed, it was inside the case. My only thought was maybe it touched something hot and responded by disabling the output? I have not yet been able to replicate it with the power supply in my house.
Help?
