Author Topic: LEADER LDC-822 Frequency Counter  (Read 543 times)
Offline samsonTopic starter
« on: December 23, 2023, 12:47:51 pm »
Has any one Calibrate the Leader  LDC 822 frequency counter. If so could you please explain the procedure.
Thank you in advanced
Offline 807
Re: LEADER LDC-822 Frequency Counter
« Reply #1 on: December 23, 2023, 02:05:15 pm »
According to the manual, the timebase is adjusted by a trimmer cap accessable through a hole in the bottom of the case. Of course, you will need to supply the counter with a suitably accurate frequency for the calibration to be meaningful.
https://www.download-service-manuals.com/en/manual.php?file=Leader-3764.pdf
« Reply #2 on: December 24, 2023, 08:24:39 pm »
Thank you for the reply. In the manual it doesn't say which gate button to press to do the calibration. It's confusing.
