Author Topic: Leader LV-76A …or, is it?  (Read 1047 times)
Offline W3KWTopic starter
« on: December 01, 2022, 03:13:36 am »
I own, what the label reads anyway, a Leader LV-76A VTVM. It really seems like a quality meter and is very accurate for an analog machine. I spent some time adding an internal fuse, new power cord, and basically cleaned and calibrated it. I was able to find a manual for the LV-76B, but only the schematic for the LV-76A. This is where a mystery has unfolded. The -A model schematic, which matches the label on the front of my meter, only has two tubes. The -B model has an extra 6AL5, or three tubes. My -A model meter has three tubes! What? That doesn’t match the schematic for -A model.
Does anyone own a -B or -A model and notice the discrepancy with the manual?
See photos.
Wes
W3KW
I don’t yet understand why the forum randomly rotates my photos. Sorry about that.
« Last Edit: December 01, 2022, 03:18:10 am by W3KW »
Offline Writerone
Re: Leader LV-76A …or, is it?
« Reply #1 on: January 12, 2023, 09:05:07 pm »
I did a search equally confused because mine is a B and I'm seeing only two tubes. I wonder if the previous owner replaced the case, or if mine is heavily modified. I'll have to look for a 76A schematic as well because this doesn't seem to match the 76B directions I got from BAMA.
Offline Writerone
« Reply #2 on: January 12, 2023, 09:38:45 pm »
I did a little sleuthing, and it's pretty clear I have a 76A in a 76B case. The devices and values all align with a 76A schematic. Fortunately I just picked it up at an estate sale and don't feel like I was misled by the model number. If I can help in any way, let me know. I'm trying to decide if I should recap mine or just let it ride.  I thought I had more to work with, but I don't assume the procedures in my 76B guide apply to the 76A.
Offline oz2cpu
    • webx.dk private hobby and diy stuff
« Reply #3 on: January 12, 2023, 10:01:10 pm »
wow that is so nice the older tube based one..
in case you like to see mine, the a bit later, transistor based version
Leader LMV-89 from 1970 to 1975
https://youtu.be/6lmpMzdiLUU
Radioamateur OZ2CPU, Senior EE at Prevas
EMC RF SMPS SI PCB LAYOUT and all that stuff.
youtube : oz2cpu teardown
Offline william_b_noble
« Reply #4 on: October 27, 2024, 04:34:59 pm »
since at the top of this topic someone posted that they had found a schematic for a LV-76B, can you tell me where you found it.... I have a B and a resistor is not connected, I'd rather use a schematic than work backwards and then guess and hope   .....update - I found it on BAMA   https://bama.edebris.com/download/leader/lv76b/Leader%20LV-76B%20Instruction.pdf
« Last Edit: October 27, 2024, 11:20:57 pm by william_b_noble »
Offline Writerone
« Reply #5 on: October 27, 2024, 06:08:45 pm »
That might have been me. BAMA is the Boat Anchor Manual Archive, https://bama.edebris.com/.
The following users thanked this post: william_b_noble
« Reply #6 on: October 27, 2024, 11:23:41 pm »
Thank you, I found the manual a few moments before you posted - And, I was able to repair the meter, I found two broken connections, one on a 19.5meg resistor one a wire (that was really hard to find) - I ended up putting 5VDC on the input and following it until it disappeared at the divider, and a tug on the wire from the mode (AC/DC etc) switch to the range switch revealed the problem when the wire just pulled out.  It's a nice unit.  it will sell to pay for more fun test equipment ....2416123-0
« Last Edit: October 27, 2024, 11:25:45 pm by william_b_noble »
