So here some photo of the inside of the lecroy wavesurfer that I found and picked up in a trash at my university.
Nice find! The WaveSurfer 400 was LeCroy's first suitcase format scope. It was made by Iwatsu which means the build quality is very good (better than som of the subsequent WaveSurfer/WaveRunner models). The CPU is a P3 Celeron on a board with a VIA chipset running Windows XP Embedded. It's a pretty slow system but the WaveSurfer 400 didn't had many options and was a more basic scope so that was not much of a problem. Still, it has the great MAUI user interface with touch screen, and makes still a great general purpose scope.
The WS400 is a X-Stream scope, however because of the slow processing support for this scope was stopped several years ago, which means the later X-Stream software updates won't work on it.
Someone know where to find the "WS400 Series Control Program" dvd, and the "Startup Disk for WS400 Series Control Program" floppy disk? I need them for the reinstall the os.
No, you don't. You can re-install the scope with a generic Windows XP Pro CD with valid product key (the Embedded one won't work!). However, what you need are the factory calibration files that are in the 'calibration' folder on the 2nd hard drive partition (d:). Without them the scope will not work. So if your scope has still the hard drive the first thing to make sure is to create a backup of that folder.
Calibration data aside, all you have to do is to create two partitions (C: and D:). After you have installed XP restore the calibration data on drive D:, then go to the Teledyne LeCroy website, download the last software package for the WaveSurfer 400 and install it. Voila, scope restored.
While you're at it I'd recommend to replace the (by now probably on its last legs) 2.5" EIDE hard disk with a modern EIDE SSD (i.e. Transcend, not crap like Kingspec!), which makes working with the scope a lot nicer.
