Products => Test Equipment => Topic started by: ciasteczkowypotwor on July 13, 2018, 01:58:38 pm
Title: LeCroy 9350A WPA02 option
Post by: ciasteczkowypotwor on July 13, 2018, 01:58:38 pm
Has anyone installed options WPA01/02/03 from a memory card, or FDD. Maybe someone has the necessary file?
Best regards
Wojtek
Title: Re: LeCroy 9350A WPA02 option
Post by: Emo on July 13, 2018, 02:22:56 pm
Hi Wojtej
The Lecroy uses a GAL chip. Fortunately the chip can be programmed yourself or sometimes a seller on ebay does release a batch of them.
In the leroy owners group on Yahoo, the chip contents can be downloaded
Post by: ciasteczkowypotwor on July 13, 2018, 04:52:16 pm
You right, it's only firmware update. 39/5000
There is no GAL at all, there is an empty stand.
Post by: scopeman on July 15, 2018, 04:13:04 pm
All of the 93XX, and LC series need a 16V8GAL to enable the WP01/2/3 MC01 and somw other options. I have attached the JED file that you can use to burn into a DIP package 16V8. This GAL will enable all of the useful options on the 93XX series.
Sam
W3OHM
Moderator
LeCroy Groups on Yahoo! and Groups.io
